Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
Date: 09/01/2017 07:52 am
72 pinto
Date: 06/23/2016 12:40 pm
Date: 10/04/2019 08:43 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Need Interior Panels
Date: 07/09/2018 04:59 pm
  • Online today: 548
  • Guests: 451
  • Total: 451
sport mirrors not too adjustable using knob
Started by russosborne, May 03, 2009, 05:09:07 PM
The cables themselves might need some lubrication. I suggest trying some silicone spray or white lithium spray. WD-40 will evaporate so I wouldn't suggest using that.
Also you might want to pull your door panels & see if the cables are moving when you use the knob. If they are that could be your issue. If that's the case try using some plastic zip ties to try to secure the cables in the doors. Just a thought, couldn't hurt.
Maybe they just aren't supposed to be as adjustable as I need them to be. Anyway, while I can adjust them using the knobs from the inside of the car, they don't even get close to where I need them to be. They do move just fine using manual pressure on the mirrors themselves.
So is there a way to clean/lube the cables to get full movement, or is what I have considered full? The mirrors do go up, down,in, and out using the knobs, just not enough.
Thanks,
PS, I still haven't gotten any pictures of the driver's side knob mounting (pulling through the door)to post yet as requested about that problem. I need to get out to the garage with my camera.
