Date: 03/17/2019 10:15 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Date: 04/13/2017 04:56 am
Date: 12/24/2016 04:13 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Date: 12/09/2016 08:34 am
windshield
Date: 04/14/2018 08:53 pm
V8 rear end
Date: 04/12/2018 10:57 am
  • Online today: 500
  • Guests: 438
  • Total: 438
2.3l cam timing
Started by slowride, April 22, 2009, 10:26:24 AM
slowride
I have an affliction.... I can't stop when I get started on a project. It's happening to this one too. I have the new timing belt and tensioner coming Monday, so I'll continue with my plan to try advancing the cam, then replace the belt. I doubt I'll pick up the advance I need on the cam with just teh belt replacement, so I'll be getting an adjustable cam gear (actually it's a sprocket.. I HATE it being known as a gear, but anyways) and seeing how much advance it takes to overcome the smog grind.
Any preferences on gears? I've seen the Esslinger and Racer Walsh (favorite $o far), and the Summit multi-key.
My 2.3 auto pinto will leave my two 2.3 4 speed pintos in the dust. I dont know why. The engine i put in that car (the one with the auto) is from an old junk pinto that hadnt run in years  when i got ahold of it for free. It has blowby which the other two dont have. It has a 3.08 ratio and the two 4 speed cars have 3.00 (on the 76) and 3.55 on the 74. I dont understand it unless it has an aftermarket cam or something. I wouldnt think so tho. I am extremely surprised at the power it has, i was afraid the auto would really kill it. But it will burn the tires and the two 2.3/4 spd ones wont. Even the 74 with 3.55s.  Anyways I sort of digress. The 74 doesnt have much power at all, I am not sure what is wrong with it. It bogs down when you take off and even with your foot on the floor it feels like you could run faster. I dont know if its a cam timing issue or what. It has had the head shaved a bit when i had the head rebuilt, that may effect it some. It may also be the point type ignition. I dont think it burns anywhere near as hot. It has always shook violently when you rev it up with no load on it, mainly when cold. I dont understand that either. And it sort of makes a "farting" noise for lack of a better term when i let off the throttle to shift. Does this stuff sound like cam timing??
I won't argue with one's success. My experience has been mainly with Datsun 510's and Mopar 318's.  These are 1973 smog era cars and moving the timing produced no perceptible difference in my case.  At least in the 318 there are claims about the significant retardation built into the cam as well.  If the alteration works on the 2.3 that is great.
I'll certainly agree to the cars with automatics needing all the torque they can get.  My Auto, 2.0 couldn't even get on the trailer without human assistance.
Tom
[.  But on the street it likely is imperceptible.
Tom
[/quote]
I have to respectfully disagree. An automatic Pinto needs all the low end help it can get. Add to that the cam is likely retarded to begin with, so even getting it back to zero is a big help. I advanced the cam on my wifes 2.0 Pinto 2 degrees, but the overall correction was 6 degrees and even she noticed the difference.
slowride
Looking at the front of the engine, it rotates clockwise, so advancing the cam would be moving the cam clockwise.
Which way is advanced on the cam gear? When its one tooth above (to the right of) the pointer, or when it is one tooth below (to the left) of the timing pointer?
slowride
Quote from: Wittsend on April 23, 2009, 01:51:40 PM
With 38 teeth on the cam sprocket I get 9.475 degrees at the cam or nearly 19 degrees at the crank per tooth.  Most offset keys only go to 4 degrees. So, I would assume much more and a different grind would be more in order.
With such little torque from the 2.3 and the fact that degreeing only moves, not creates more torque I'd think changes would show little difference. Yes, maybe in a race that is won by a few feet all other thing being equal the timing could make the difference.  But on the street it likely is imperceptible.
Tom
Keep one thing in mind.... I'm working with a stock cam. They were ground retarded 4 degrees and often more. Most aftermarket cams are ground advanced, so you wouldn't NEED more than 4 degrees at the crank.
slowride
Theoretically, advancing the cam (to a point) builds more cylinder pressure as you are closing the intake valve sooner. I suspect the result of advancing the cam 1 tooth will bring torque in sooner, but will flatten whatever powerband there is drastically. My main focus will be when I replace the belt..... advancing the cam on the old belt first will just be playing.
Tom
.030" = about 2 degrees. I think one tooth advanced will be too much, but hey, it's worth a try. I think timing belts do stretch with age, I've replaced belts on many cars (mine included) and they ran better. Longer belt = retarded cam timing.
slowride
Quote from: dick1172762 on April 22, 2009, 05:34:56 PM
One tooth is 12deg.
So let's see if my math is right.
12 degrees minus 4 degrees (retard ground into the cam for smog back then)= 8, minus 2 degrees advance (over "straight up") I want would leave it 6 degrees advanced. Any surfacing or milling done in the past would decrease that figure also. Problem is, I don't know if it's been surfaced before... I was told the engine is untouched, but I've had sellers tell me THAT before.
Does anyone have a guess as to how many degrees it retards the came with a .010" (for instance) surface?
slowride
Quote from: 71pintoracer on April 22, 2009, 08:24:10 PM
Look at my post under "Your Projects" called "Cam Timing 101"
This should help answer your questions. Currently on page 2.
I read the thread... very informative. I don't know that I want to replace the cam sprocket with an adjustable at this time, but I'll replace the belt and tensioner, then see if there's any difference. Buying a 35 year old car leaves a lot of questions to be answered.... has the head been surfaced/milled and how much among others.
I did advance the timing again just shy of detonation under load and it's better. There's a very small timing range with an automatic, so hopefully the new belt will help. I've heard belts don't stretch, they break, so we'll see.
Mike Modified
Stolen from http://forum.merkurclub.com/forum/index.php on setting cam timing without an outer cover:
"If you run a string from center of cam bolt to the center of the aux sprocket bolt, line up the pointer on the cam gear to this. Obviously there are a few steps you must do first to get it to TDC, but it is a way to set your timing without the rear timing cover with the pointers."
slowride
After reading a bit more here and other places, 1 tooth may be too much, so I'm going to do 2 things. First, advance the cam 1 tooth and try it. Second, I have a timing belt and tensioner coming and will replace the old one. I don't know how old this one is, how stretched it is, or even if it IS stretched. when I'm done I should be able to tell what the problem was and what ultimately fixed it. Worst case scenario is I will have a new belt and tensioner and won't have to worry about it breaking for some time.
slowride
Since I got the wagon I have been less than impressed with the low end torque. Granted it's a 2.3l 4 cyl and I'm used to built big blocks, but I'm 99% sure the cam timing is retarded. My outer cover is missing, so I chose a spot next to the damper, found TDC and marked it. I checked the mark on the cam sprocket and it appears to be correct, however, since I opened up the exhaust and backed the ign timing off a couple degrees (to eliminate a slight ping on accel), it has developed a "sneeze" when I punch it at low rpm. On any one of my other cars, this would indicate a retarded cam. I should degree it, but in the interest of saving time, I'm considering just advancing the cam 1 tooth and testing it. I seem to remember that the 2.3 is a non interference engine, so there shouldn't be any downside to doing this other than a possible waste of time.
Has anyone else tried this shortcut or have any info?
