75 wagon need parts
Date: 05/28/2020 05:19 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 07/10/2016 10:17 am
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Date: 07/13/2018 02:21 pm
Date: 10/24/2019 01:43 pm
Date: 03/07/2017 07:03 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
  • Online today: 529
  • Guests: 493
  • Total: 493
Wiring diagram to change from duraspark to TFI distributor
Started by dcorry, April 21, 2009, 10:51:19 PM
dcorry
Completely forgot all about the vacum advance on a street car,I had a TFI distributor on my race car also ,Now that I think about it I really need to stay with the duraspark ignition.Next time i'm at the junk yard i'll get me a spare or two ..Glad I came in here and checked this post got the hood up on the car and the distributor cap off was going to attempt the swap.Thanks guys you saved me a big headache
Hurricane Katrina victim saved from the scrapyard  --79Pinto--
Good point! While it is only going half way, is the vacuum part of the old to new adaptable?  There is that metal rod that holds the PIP stationary?  Will the vacuum canister mount there?
That aside, (given its limitation) 71PintoRacer is correct the TFI needs a computer (and all the other input sensors) to set the timing dynamically when the engine is running.
Tom
Ummm, the TFI will only work on a race car because the advance is controlled by the PCM. When it is installed on a car w/o a computer the advance is stationary. I ran one on my dirt track car and would have to get the engine cranking over before flipping the ignition toggle so it would start.
Just wondering, why do you want to get rid of the duraspark?
dcorry
Need help in changing this old duraspark amplifier box and distributor out to a TFI distributor on my pinto wagon with a 2.3 motor.Any help would be appreciated so i don't short out the TFI ,or spend all day on running back and forth to the junk yard chasing down wiring.Can't be that much to it and i'm sure somebody on here has experience in changing them out .......Daniel
