Date: 10/25/2019 04:05 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Oddsnends
Date: 12/20/2016 10:52 am
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 03/25/2019 09:02 pm
Date: 04/06/2017 12:13 am
Date: 02/18/2017 04:44 pm
  • Online today: 481
  • Guests: 376
  • Total: 376
2.3 timing marks
Started by beertp, April 15, 2009, 10:38:59 PM
I assume with your described ignition you are asking how to keep the cam in time with the crank when changing the belt.
I use paint (spray it in a can and apply with a Q-tip)don't use a marker.  I put a paint mark on the belt and the cam pulley tooth that corresponds. I do the same at the crank end.  I remove the belt.  I match the old belt up to the new one and mark it the same.  I then install the belt so the marks on the new belt align with the pulley marks.
I do this on any car I change the belt on.  Especially on the 2.3 there is an indicator on the rear plastic belt cover.  A lot of times that is broke off.   Other times people just pull the cover and have left it off.
Comprehending marks listed in manuals can be difficult.  Some times a tooth either way seems wrong and the perceived tooth doesn't seem right either. You can go nuts.
As long as you know the belt was originally correct I would use the "paint" method every time.  You always have the old belt as a correct original reference.
Tom
beertp
yes no distributor it has a porsche hi output coil pack distributless ignition,and yes it has something like that on crank,although kind of different,i will try to take a pic if i can figure out how to post it,thanks for the help.
Mike Modified
No distributor???  Do you have something like this on the crankshaft???
beertp
Hi iam new to the pinto motor I have a 2300 in my sandrail and the crank seal is leaking,how do you keep in time when you pull the pulley,I dont see no arrows or normal line up, this has a lot of esslinger parts and no distributor,it has hi output coil pack.any help would be appreciated
