80 pinto original
Date: 08/04/2019 10:45 am
Date: 02/05/2017 09:45 am
1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
1979 Pinto Sedan Delivery
Date: 06/15/2019 03:30 pm
Racing seats
Date: 10/24/2019 09:41 pm
FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 07/03/2025 04:35 pm
  • Online today: 489
  • Guests: 358
  • Total: 358
1/4 window R&R
Started by Carolina Boy, April 02, 2009, 11:37:57 PM
This method has worked for me with the non-flip out style 1/4 windows.  The metal trim in the rubber, rubber gasket, and glass get removed and installed as a single assembly.  If your car has metal trim attached to sheet metal, it stays put during this process.  The glass-rubber assembly gets pushed to the outside from inside the car (gentle foot power does help).  To make it easier, I coat the gasket with ArmorAll.  It makes a mess but ArmorAll seems to soften up the rubber and also lubricates it.  Be sure to get it behind the gasket, let it sit for a while, then reapply.  While pushing from inside, start at a corner and lift interior edge of the rubber to slide it out the opening.   I have had bad luck using metal tools around glass, popsicle sticks or half a wooden clothes pin may be a safer prying tool.  To reinstall: lubricate it up again, put a cord in the groove with the loose ends inside the car, put pressure on the out side of the glass-rubber assembly while pulling the cord from inside the car.  Pulling one end of the cord will lift the inner rubber flap over the metal lip.  Gradually work around the glass while pulling the cord until the gasket is in place.  Hopefully you are not in a cold climate, getting the rubber flexible is essential.
That just tickles me pink! Thanks everybody.
71hotrodpinto
Hey there, when i pulled them out of my car for a headliner install, i just worked them out from the inside. Just pull the rear seat out , then the back, then the side panels then you can get to the gasket. I just worked the window gasket out starting at the middle bottom. Yes they come out, and go back in, all as one assy.
GL!
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
This is the screwdriver thingy hubby uses!!
I will try both way. I am lucky that I have an extra set from the 76. Thanks
I like to do them on outside more working room.  Fred   :)
Fred, I don't have extra money to buy such expensive special tools like those! :lol:
Seriously, they're removed working from the inside of the car?
Installing: Is the trim installed in the rubber before the glass? Then mount the whole window, glass, rubber and trim as one?
Robert let it sit in sun 1st to soften rubber. Then pull chrome off. Fred   :)
I wear a 9 and a 1/2, is that big enough?? :tgif:
Quote from: Carolina Boy on April 02, 2009, 11:37:57 PM
What is the proper way to remove and replace the stationary 1/4 windows? Does the trim peices come out with it?
I have never done these, so I'm not sure how much this will help but, I would think you could take a window tool (a twisted pointy screwdriver) and work the rubber out from the inside.  I know when my hubby R&R'ed VW Quarter windows, he would sit in the back seat and litteraly kick the windows out, rubber and all!!! In fact that is how he got the back window out of our parts 72 Pinto!!!!
I would defenitally wait for some more experienced Pinto owners to reply though!!!!! LOL  ;D
