1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 10/15/2017 10:03 am
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
Date: 04/06/2017 12:13 am
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
New cam
Date: 01/23/2017 05:11 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
  • Online today: 553
  • Guests: 193
  • Total: 193
Won't go into reverse
Started by geoff104, March 31, 2009, 12:43:21 AM
could the pin that allows it to go into reverse come off or broke? or seized maybe? worth a look in your manual to see what it says i kow the 80 mustang my brother had, had the 2.3 with the german trans and had the same problem
geoff104
SRT,
  Thanks for the reply. It is the same with the engine on or off. I tried what you said (let the clutch out a little) but no success.
if you put it into any other gear & let the clutch out just a bit then into neutral;  will it then go into reverse?
with the engine running or off?  clutch adjustment?
geoff104
Sorry, I should have proof read! I mean the shifter depresses, goes all the way to the LEFT, but not up. Also It makes no difference if the car is on or off :rolleye:
geoff104
So I finally have the car in my posession, The shifter depresses, goes all the way to the right, but not up into Reverse. I took the shifter off and felt around in the oil, but cant find anything obstructing. Anyone have any ideas? I'm baffled!
          Thanks,
             Geoff
Out of curiosity, did you try to put it in reverse with the car off? If not you might want to, just to see if something is binding when the car is running & all. Worth a try anyways.
geoff104
Yeah, I did push down, doesn't seem to make a difference though :(
I apologize in advance if you have already done this.  Since it has been a few months since driving it, I was wondering if you remembered to push down on the shifter when trying to get it in reverse (you did not mention doing this in your description).
geoff104
 Hi,
  I have a 2.3liter 78' pinto with a German Ford transmission(this is what I was told but not really sure). After the car sat in the garage for the winter it stopped being able to go into reverse gear when I pulled it out for the summer(It worked fine when I put it away). It is a 4 speed and to shift into reverse the shift knob has to go left past 1st and than up. The problem is that the shfter will allow itself left just not up. Everything else works perfectly. Has anyone heard of this problem or know of a possible cause/solution? It's really strange and I could really use my reverse gear!
     Thanks in advance for your help, I appreciate it very much!
