1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 02/22/2017 01:58 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Date: 02/14/2018 01:34 am
Date: 04/13/2017 04:56 am
Date: 02/05/2020 11:06 am
  • Online today: 535
  • Guests: 448
  • Total: 448
v8 C4 to 6.75 rear conversion u-joint
Started by Saito, March 29, 2009, 04:15:15 PM
Quote from: dave1987 on March 29, 2009, 05:31:24 PM
If you are going to be using your 6.75" rear on a 302, don't plan for it to last long. It can't hold up to that much torque or horsepower and you will ended up detonating it shortly after you get the car on the road to enjoy it.
Agreed. I have personally never seen an adapter to that small and well, under a V8 setup, that frail of a rear end. And if they make one and you go that route, don't expect much out of it in the end. I like the enthusiasm of wanting to get the car on the road ASAP but I would make a new rear end one of the next top priorities... just my 2 cents.
My friend who does a lot of turbo stuff just went to Autozone a couple weeks ago and picked up an adapter U-Joint for about $23. He is using a C4 and 8" rear as well, with the stock drive shaft. That's on a 2.3 turbo though.
Saito
I'm was on the home stretch of installing a 302/C4 combo in my '80 Pinto when I hit a snag. The C4 slip yoke uses a larger (read longer) u-joint than the recieving end of my 6.75 rear. Is there a conversion u-joint available thats short at one span (cap to cap) and long on the other span? I have to keep my 6.75 rear for now as funds don't allow for a new rear yet. Any ideas on mating the two up? Thanks.
