72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
Date: 01/28/2021 03:49 pm
Windshield
Date: 01/15/2022 09:31 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
Pinto brake booster needed
Date: 05/08/2021 09:00 am
Seeking parts
Date: 10/18/2020 10:35 am
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 06/22/2017 07:19 am
  • Online today: 587
  • Guests: 343
  • Total: 343
8" rear swap
Started by woodie, March 28, 2009, 05:28:09 PM
woodie
thanks for the help  Woodie
watch this
Quote from: 71pintoracer on April 01, 2009, 10:10:42 PM
It did go up into the trans about 1" more because the 8" is larger than the 6.75.
BINGO...they are about 1 inch different. My old garage rule of thumb is: put the drive shaft yoke all the way into the trans until it stops (EASY does it). Then pull it out 1 (one) inch. Mark it...THAT is the MINIMUM you should allow before binding.
Ive seen so many variable answers to that question that I really don't know what to tell you! When my car was a 4 speed and I put the 8" in it, I used the same driveshaft. It did go up into the trans about 1" more because the 8" is larger than the 6.75. Try a search on the 8" swap, maybe more info there.
woodie
 I have a 1980 pinto auto will I need to change my drive shaft?  when I put in the 8" rear thanks for any help
watch this
