71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 09/01/2017 07:52 am
Date: 11/29/2018 10:26 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Date: 08/09/2018 11:09 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 08/02/2019 04:18 pm
Date: 04/15/2017 05:14 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
  • Online today: 1,009
  • Guests: 979
  • Total: 979
Head Bolt Torquing - which of the many is correct???
Started by Wittsend, March 27, 2009, 12:56:15 PM
Thank you. Yes.  What you say is apparently accurate.
There is a LOT of mis-information going on out there regarding 2.3 head bolts.  I'm put this information in a separate post with a more appropriate heading.
Bolt types:
  As best I can tell all the replacement bolts are now 6 point, TTY (Torque to Yield). They are 51 foot pounds of torque - plus a 90 to 100 degrees rotation.
  But, a lot of Ford 2.3's came with 12 point "regular" torque bolts. They are a two-step torque 50-60 foot pounds, then 80-90 foot pounds. In my case my 1988, 2.3 Turbo Coupe came with 12 points.
After searching the TurboFord site this is what I basically found:
1. If you have the 12 point bolts they CAN be reused.  I saw one comment up to three times. It was cautioned that you should ensure their condition.  If your a junk yard kind of guy like myself (cheap) I would pull some 12 point next time you are there. If the bolts are easily accessible I would recommend pulling five from the intake side and using them on your exhaust side. This obviously is 'thinking ahead" and anticipating a blown gasket.
2. If you are sceptical about the 12 point bolts (and not so cheap) you can buy new 6 point Torque to Yield bolts.  As of 3-2009 the Ford dealer gets about $28.  The aftermarket bolts are more around $40!
  The process seems to be torque to 51 foot pounds, loosen  then retorque again to 51 foot pounds, then rotate an additional 90 to 100 degrees (about 1/4 turn). I saw information that this gives an equivalent torquing force of about 110 foot pounds.
  Note - you can ONLY use TTY bolts ONCE.  They are said to clamp better because of the "bolt stretch" that occurs. Unfortunately that bolt stretch is what makes them one time only.
Lastly (if you are really not cheap) you can buy ARP studs. They are about $110.  ARP told me you can reuse them significantly "IF" you don't over tighten them.
  With anything this is only based on what I found, so apply the information at your own risk. But, frankly there was massive frustration for me in know what was right.  So, I decided to create this post.
Tom
if you use the 12 points they can be reused if in good condition and they use the factory torque method. the tty use the torque to 51 twice and then another 90*. i was curious about the torque and measured the difference of the 2 methods and the tty was about 110flbs after the 90* pull. the tty are what im using with the 8993 gasket and have pushed 32lbs of boost without failure of the gasket.
Tom ,
It sounds like the Felpro people were just concerned with the '74 to '83  apps or any HiPo builder that would use ARP bolts on any other model year. Ford has zero motivation to service these engines now, just Zetec & Duratec engine designs. A engine builder like Esslinger should give you the answer you seek.
Good hunting & let us know what you find out..
You know, the interesting thing was the dealer (the good one) said that, "Ford no longer carried the head set for this motor."  He said that I needed to go aftermarket. So, you can get the bolts from Ford, but they don't work with the gasket from Felpro?
I'm just baffled. I see posts that all the time stated to go to Ford for the bolts (best price) and Felpro for the gaskets (8993).  But I have never heard anyone comment on the different torque values in each manufacturers instructions.
Yes, I too thought it strange that it was a steel on steel application with TTY head bolts.  By the way, I thought all the 2.3's were TTY?  My understand is that definitely the 1988 2.3 (at least the Turbo) was TTY.  If Felpro specs their gasket for that motor then why a different torque value???  It is just so annoying that that the difference exists and perhaps even more so that others haven't addressed it by now.
Tom
Here's an update:
Apparently in 1983 to 1992 2.3L OHC fords any time the head gasket is changed to the new style Gasket, the new style TTY bolts must be used. The question is; What style bolts does Felpro recommend? Or will you use a New style Ford gasket, and then the New TTY would be compatible.
This is from the Feb 2009 Engine Builder Tech Solutions Guide under a revised procedure for 2.3L OHC Ford.
Tom,
It sounds like you have a Conflicting set of instructions and applications .(DuH I know!) Felpro may have made the gasket for all 2.3 installs but then maybe not all of the 2.3l ,if any, used TTY bolts (Torque to yield) . Normally a standard grade head bolt has a fixed torque usage based on engine design and head materials.
An engine with dissimilar block and head materials would need a TTY style head bolt to allow for the different expansion rates. Unless you have an alloy head I would check with an engine builder first. Then you can decide with confidence which type of Bolt is needed before you install the head.
My 2 cents,
The bolts were $27.26, plus TAX!
And, yes, that was for the box of ten.  As one member found it was not per bolt.
  I'll add too that I called two dealers. One said there were two different sizes and that they were $6 each!
  It makes you wonder some times.
  By the way, I applied to use the TurboFord forum last night.  I got an email saying I would "shortly" receive approval.  That was over 14 hours ago and nothing yet.
Tom
Mike Modified
Tom,   I don't have an answer, but I'll bet that they know on www.turboford.com
BTW, what did the new head bolts cost you?
Let's see, where do I begin (2.3 1988 Turbo)?
The Felpro headset instruction sheet says:
"Torque the head bolts to 80-90 foot pounds (it never mentions replacing them either). Disregard any other lower values (in manuals/instructions).  Otherwise the gasket can fail."
The instructions that came in the Ford F3ZZ-6065-FB head bolts says:
"Torque to 51 Foot pounds then rotate bolt 90-100 degrees"
So, is it 51 foot pound then rotate 90-100 degrees?  Or is it torque to 80-90 foot pounds?  The two instructions contradict each other.  I'd sure hate to snap a bolt using the Felpro method, but I'd hate to cook a gasket using the Ford method.
And, while I'm asking, the original bolts had the multi point star head. These replacement bolts have a hex head.  That is a lesser issue.  But, the replacement bolts  are threaded nearly to the top, while the originals were threaded much closer to the bottom and had a more solid shank.  Can anyone explain?
  Lastly, I previously did the "No-No" of re-using the original bolts.  Oddly my lost compression issues weren't from the gasket/bolt combination, but a burnt valve.  So, it leaves me to wonder about the whole bolt replacement issue in the first place. ???
  Anyway, I'm ready to bolt the head on today, so if anyone can accurately respond it would be GREATLY appreciated.
Thanks, Tom
