71-71 speedo cable
Date: 07/31/2021 09:04 pm
Date: 10/11/2019 11:13 am
1973 Pangra
Date: 01/06/2015 02:19 pm
Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
Date: 11/12/2020 08:28 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 09/15/2019 08:30 pm
  • Online today: 553
  • Guests: 280
  • Total: 280
couple of quickie question on rear springs
Started by dholvrsn, March 24, 2009, 07:38:13 PM
Hey guys it's been awhile sinse the question was asked but I got my rear leaf springs front a place here in town that makes them from scratch according to oem specs. and they will mod. them any way you want....as I had an additional leaf installed in the forward section to act as an anti-curl traction bar. They were able to come up with all the stuff I needed for the entire overhaul. It was about 500 bucks for bushings, shackles and springs. The place is called Atlas Spring and axil.
I got a couple of used springs from Fred Morgan.
Don:
  Did you get new springs? If so, from where? I think I want to pull my units (wagon also), and have them refurbed.
dholvrsn, on my 77 wagon with v6 and 8 inch rearend the leaf springs are identical. See my thread about ThunderPinto gets a posi rearend. Tip....Warm up the nut bolt area with soldering torch...not to hot...200 max. and then cool down by spraying wd40 or equivelant penetrant. The cooling/contraction of metal will draw the penetrant into the threaded areas. Smear a bit of anti-seize on the threads while warm...impact away.
Are left and right leaf springs different on a wagon? If they are, how do you tell which side is which?
Any tips and techniques on getting those nasty rusty front shackle bolts out?
