Date: 08/03/2018 09:19 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Wheel cap
Date: 04/25/2022 11:21 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 03/18/2020 01:30 am
Date: 03/16/2017 10:00 pm
Date: 11/04/2018 02:34 am
  • Online today: 452
  • Guests: 277
  • Total: 277
horizontal scratches on the cylinder walls...
Started by kemerick, September 20, 2004, 08:53:22 PM
kemerick
sounds correct to me as the #3 cylinder got way too hot it looks like as the exhaust valve is white due to the carbon being super heated...
thanks guys !
Poison Pinto
My knee-jerk-know's-nothing-but-willing-to-take-a-guess reaction is:
The car has sat or slightly overheated and the rings became lightly "welded" to the cylinder walls. When the car was restarted, they broke free. My guess is honing the cylinder(s), cleaning the ring groves in the piston(s), and replacing the rings will suffice.
I'd pull the piston and look at the ends of each ring to see if the end gap is too small. Those 3 scratches are about at the same location as the rings when the piston is at top dead center. If the but end of the rings shine, that probley your problem.
 No, that is not a crack. 2.0 blocks dont realy crack. It is an interesting set of scores. I would run a hone through it and see if it cleans up.
kemerick
These three horizontal scratches on the cylinder walls appear to be only a couple thousandths on an inch deep... my concern is how they were caused?
I believe honeing with a drill with one of those starburst looking things with the balls on the ends will remove them... but I am wondering if were caused by cracking?  I looked through one of the coolant channels and I can not see a crack... just makes me worry.
