turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 04/08/2018 05:47 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 10/01/2020 02:00 pm
Date: 09/15/2019 12:28 pm
Date: 07/01/2019 03:17 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 09/02/2021 08:21 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
  • Online today: 535
  • Guests: 406
  • Total: 406
78 Crusing wagon restore
Started by flash041, February 26, 2009, 04:22:33 PM
flash041
spent three hours grinding old paint off! Got the roof done , parts of the hood and front fenders.Tonorrow I will take final pics and measurments of the stripes , then remove them.Getting an estimite to have the paint work done. I showed the work I have been doing to a body man I know and he thought I should paint it myself.I would but not sure about the overspray in my atached garage even with an HVLP gun.
flash041
Wen I got home I thought id try to get the tach working.I got two spares.Itres them both , one WORKED! Tach again! Also ive started to sand the old paint off.
flash041
Got our in the nice bright sun (about 11 above this morn) for a little cruise today!Wen to the graphics place.Have not come up with the estimite for the stripes yet , but matched the colors as best we could from an unfaded area where the stripe wraped around the door. We came up with 3 colors, 3 mfgs.Avery Plum #9440-0 , Orical  orange-red #047 , 3M chrome yellow. Has any one else done this , and do you have the colors you used.Or if painted the paint codes.
flash041
It Finally quit snowing for two days! The roads are clear and I am driving the Pinto to a graphics place so they can take some pics of the car to get an estimite for recreating the stripes.Then I will take it to the body shop for some advice on getting it ready for paint.I have started to sand the paint off .
flash041
pics
flash041
Cant post any pics it wont let me upload them says its full.
flash041
Got the gas tank back in along with new fuel and vapor lines.Got it started, first time since fall, it sounds GREAT!
FlyerPinto
1977 Bobcat HB
1977 Bobcat HB
1978 Pinto Cruising Wagon
flash041
se how much it would be just for the kit.I woul install it or have my body guy do it.In the mean time ill check with a shop here to see what it would cost .
FlyerPinto
I took the partial stripe kit I have and numerous photos and measurements folks have sent to me down to the graphics shop. They will do it all for under a thousand dollars. With one kit it is a bit more expensive, with multiples the price will come down. However, they also said they could produce the sets in a fashion that would allow them to be mailed to a graphics shop elsewhere for installation. I'm excited about it; I know I'm going to do it. So if you or anyone else is eventually interested, I can fix you up. Good luck on your project.
1977 Bobcat HB
1977 Bobcat HB
flash041
got the tank area undercoated and ready for the tank.Where the tank was leaking I used aproduct called Grapple ( I sell it )I put a layer on the leaking areas and any place that was pitted , to prevent it from leaking in the future.
flash041
FlyerPinto
I'll let you know as soon as I know.
1977 Bobcat HB
1977 Bobcat HB
flash041
I did quickley look at the colors of vinyl , and found that violet lookerd really close to the correct color fir the 3rd stripe.I always thought it was purple.
flash041
Yes I now plan to get new decals too.I was going to paint them on , they would sure last a long time.But it would just not look right.I have a local company that is going to give me an estimite for making them.Let me know how much you are being charged.Tell them you may have a second set sold if the price is right.The person here was going to use soild vinyl instead of dyed , so it would last a lot longer than the original.l
FlyerPinto
In case you're interested, I'm restoring a 78 Cruising Wagon as well. I am going to see a graphics company Monday to have them recreate the original stripe package for my car. It is the same tri-stripe you have on your photo. Need a set? I'll know where to get them soon enough!
1977 Bobcat HB
1977 Bobcat HB
flash041
Started grinding on the gas tank today.It did not leake before....now I have TWO HOLES LOL. They arent too bad and I think I can epoxy them.They are both on the top one next to the return line the other on the flat where the spare goes.The tank is not the original , I replaced it about 12 years ago, the last time it was on the road.I wont work on it any more this weekend,got a fun weekend with our convertible club.(convertibles optional it was minus 5 this morning ! )
flash041
The "treatment"hu.. I think ill need a little break when mine is done!Well the tank area is treated and painted.Now I have to warm up the garage again to undercoat it.Then get the gas tank ready to go back in.
LOOKING GOOD!!!!  Now when you are done, I have a certain white Squire wagon that needs the treatment  ;D
flash041
Its time to get on my back and get dirty.I want to get the gas tank back in.Before I do I needed to get rid of the rust above where the tank goes.Below are a couple of pics before i started to sand/wirebrush it off.I did not find and new holes.I stripped off the loose rust and paint then treated it with rust converter.Tomorrow Ill put on a coat of paint and the next day undercoat it.Ill have more pics Tomorrow.I am too beat right now to take them!
flash041
Started to weld tonight. I was down to my last seven spot welds and I RAN OF OF WIRE! Oh well I ordered more yesterday , ill get it tomorrow.It is looking good.I put the cruising panel in place , it fit perfectly! I am really getting excited now!
blink77
Dave
That is such a good idea to use panel adhesive. I hadn't
thought of that, but that is the way I'm going to do mine
also. No warpage either!!!
flash041
gas filler
flash041
Finally started attaching the quarter! I finished the innerfender work and I am ready to weld.Yesterday I used a two part adhisive around the wheel well and gas filler area. it will be almost as strong as welding, and will be less likley to rust in the future. Those were the main troble spots on the original quarter.
flash041
2 1/2 straight hours work tonight! mainly grinding rust,drilling holes in the quarter for the spot welds.I have a new deadline to meet.January 2011 Word of Wheels car show in Milwaukee ! We ,78squirewagon and who ever wants to join us , will have a special display for the 40th birthday of the Pinto.
looking good, carlisle is good motovation keep it up
flash041
Ive got to keep it up , it needs to be ready for Carlisle 2011 !
Excellent work, keep it up! That's a big job....!
flash041
an hour her 10 mins there andI am making progress!Got the quarter rough fitted.Looking GOOD!
flash041
Got a little bit of work in today,too many other hosehold duties .Here is a pic after I got to quarter off.There are a few spots on the inner fender that need new metal, but not too bad.Arouund the filler tube and behind the wheel.
