Date: 10/31/2018 12:04 pm
A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
Rare parts for sale
Date: 09/10/2018 08:38 am
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 03/06/2017 01:19 am
Date: 08/08/2017 01:44 pm
'80 Pinto Wagon
Date: 02/01/2018 05:20 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
  • Online today: 656
  • Guests: 584
  • Total: 584
78 Crusing wagon restore
Started by flash041, February 26, 2009, 04:22:33 PM
flash041
Four stright hours of work and the body and doors are primed! Now I have to wait three hours to sand the jams so I can paint them and mount the doors , hood , hatch, and panels.
flash041
Two part ,an Etch primer , then a filler primer.Yea I am getting excited too!!
Now that I have wiped the drool off.....
...WOW....
....I can't WAIT to be where you are in your process. You are gonna have one awesome vehicle. Nice, nice work. A sealing primer, I assume?
flash041
Pics
flash041
Let the painting begin! I started the painting process tonight.I etch and fill primed the side panels , hood and hatch.Tomorrow I will do the doors and the rest of the car.I am doing the priming now in my garage and will do the color in the spray booth when its done.
flash041
Helped a friend last night get  a spray booth out of storage he bought five years ago. I will help him put it up , and I can use it to paint my car in. Hopefully it will be put up by next week.
flash041
It was nice to meet you too.
Looking good man. Was nice to meet you when you were here.
flash041
Got my primer and paint,ordered a new paint gun set, and a new carpet.Hope to be painting within a few weeks!
flash041
Finished spot welding the panel in. Filled in the seames and then some sanding.I drenched the inside with undercoating till it ran out the drain hole and small cracks so it in all sealed up.
flash041
Got the panel part way on tonight.On the top I used the punch/flange tool to make a recessed edge for the new metal.I decided to glue the top like I did the door edge to lessen warpage.Tonight I will let the adhiseve cure and tomorrow weld the rest of the panel in.
flash041
Ok spent a couple of hours tonight working on the rr quarter.First I cut off the patch I did a few weeks ago.Then I removed the inner fender and extra metal from the panel I got from Fred.I did a first fit and already feel much better!The patch I did was just not quite right.Afew more hours of grinding fitting , and welding and it will be done!
flash041
Got the last piece of sheetmetal today from Fred Morgan , thanks Fred.Its a rr quarter section.I made one , but was not entirely happy how it came out. I will cut that one one and fit this southwest sheetmetal in. This will be much better!
flash041
got the doors done today!Now just waiting for the sheetmetal from Fred (not here yet ,coming pony express?lol) then put that in and do final prep for primer!
flash041
Got an estimite for doing the stripes.Betweeen 700 and 800 to have the stripes made and put on.I have a little while to decide.It would save me a lot of time masking  and painting each color.
Fantastic work and progress. Congrats on a fine job, keep it up! I love the seeing major projects come together!
The wagon is coming along AMAZINGLY!
I can't wait until brownie has a freshly rebuilt engine in her and all nice and drivable as a daily driver so I can do this to my 78!
flash041
Now putting on the lower door skin panels.Rember I cut off the bottom three inches of the outerskin, and repaired the inner flange that was rusted.I bought universal door skin patch panels.Thet were 60 inches long x 5 inches wide , with the bottom edge already folded.On the existing skin i used a air flange tool to make a crimp in the panel so the two panels would fit flush and require miniumun body filler.Like the quarter wheel lip I used structrial adhiseve.I then put in a few spot welds at the crimped jount for good measure.Before folding the edge tight I filled the viod with seam sealer.Then a little fill and sanding and its done!
flash041
the rest of the hinge pics
flash041
Today I replaced the door hinge pins and bushings.I figure since the doors are off it a good time to do it.I used Lawson Products part numbers 29823 door hinge pins and 96096 door hinge bushings.They are listed for Ford trucks 1985 and up.First I groung off the peened ends of the old pins.I drove them out and then drove the old bushings out. The new bushings have a larger outside diameter that the old ones. You can see the old and new side by side . It took a 15/32 drill to make them fit.I figure it a good thing to have the bushings be a little bigger if your hinge metal is a little egged out.I then drove the new bushings in, they are nice and snug!Then drove the pins in.For a little added insurance I put one spot welded on each pin to ensure that wont back out.
keep up the good work... looking forward to seeing the result  ;D
flash041
more welding , grinding, filling sanding...Will take a break from it next week then get back at it.My goal is still to have all metal work done by the end of April , paint in May.
LOOKING GREAT!!!  Now hurry up so I can get the red coupe out to you to work on next  ;D
flash041
Today cut the bottom three inches of the outer door skin off on both doors. I was going to just glue a new piece on , but decided to do it right and get rid of any rust in the bottom lip.As you can see the inside of the door skin is mostly rust free except on the lip.The out side also had pretty bad scabs up to three inches up , but not comming from the inside.
flash041
Got the doors off today.The bottom on one was worse that I thought.Nothing that a little new metal wont solve.It was a warm and sunny day so I backed it out to clean the garage a bit.My wife cam home and said it looked sad.Have to remove the paint from the jambs, then all the paint is off!Then finish sand and fill, panel by panel.
flash041
Paint is more that 3/4 off!Tonight I decided to remove the paint from the right rear quarter.I wanted to replace it , but now I am going to repair it.It has two holes in the bottom and some rust scabs.I ground and blasted the scabs, and they are not all the way through. Also the wheel lip is all intact .So I will weld in new metal in the holes and seal where the scabs were.
flash041
More grinding and sanding . ill be gald when this step is over! It is getting closer to paint each day,
flash041
I used tracing paper and laid it on the car and pencil traces the stripes.I also pencil shaded the body lines door and hood gaps to know where they go.I  have just six sheets of paper.I traced all the lines together so I have all the size and spacing of the stripes.
Flash on your templates you make.. record where the seams in the vinyl go as well!!  Put a pencil line through the template where the seam joints are and write on the template lap joint here !If you don`t have any seams in your stripe`s forget this part ... Cut capital letter T`s from bristle board  and line the top of the T with the moldings and mark where the stripe`s original placement was with a pen on the T,,,,make a pile of them to go around the hood and back and one side,,,And number them 1 through 25  I put one T every foot on my car..Then when the stripe`s are applied they will know exactly where they went ....This stopped all the guessing looking at  old  photo`s as a reference P.S record where the first T was placed and keep a record of the measurements between each T this will help when you put the T`s back in place to line the stripes too......\  Some of your T`s will have long bottoms,,,where the stripe`s dip down low on the wagon `s body
flash041
Yesterday I spent five hours, mostly griding paint off and removing the front bumper,front inner fenders, grille and headlight buckets.At the end I finished sanded a small section.It came out nice and smooth!! Today I will do my last trace of the stripes,on the front fenders. Then its off with the stripes!
