Date: 02/18/2017 04:44 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 02/04/2018 08:26 am
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Racing seats
Date: 10/24/2019 09:41 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 08/06/2021 02:23 pm
Date: 06/18/2018 03:47 pm
  • Online today: 1,972
  • Users: 1
  • Guests: 133
  • Total: 134
  • cbdpxp
Replacing factory ball joints - a heads up!
Started by dave1987, February 23, 2009, 03:09:45 PM
Rocket
on my pinto when I replaced the ball joints I left the controll arms on the vehicle and just used an air chiesle with a torch to get them off. once you get the rivets cherry red it comes off like a breeze
Update on bolted in ball joints:
If you ever have to change a ball joint after replacing them the first time, it is VERRRRY easy to do! I just finished replacing the upper right side joint due to the boot tearing (boot didn't inflate properly??), and it only took me about 30 - 45 minutes to do! If it was still riveted into place, it would have taken me an hour or two with the tools I have available.
Technically you COULD leave the control arm on, but it would be much harder to removed the rivets. The more room you have the more angles and options you have to cut and punch them out.
So you definitely have to remove the control arm to replace the ball joints? Good fact to know. I was gonna try to replace mine but was going to leave the control arm on the car.
Pangra74
I bought some replacement control arms from AutoKrafters (I think) which ended up having defective ball joints which would not take any grease. Talk about a hard ride!!They sent me replacement joints. I just drilled out the center of the rivets and knocked them off with a chisel. I'm going to go back to stock bushings. These urethane ones that came with the arms don't work correctly either. What do you expect from crap made in India??
Joe
1974 Orange Runabout
I was going to use a grinder on mine as well, but had no discs for it.
Also, I don't think many of the other members have an air compressor. An AC makes everything easier, as you know Lost Coz. :)
Lost Coz
When I did the front of the 73, I used a body grinder and just ground the heads off, then knocked them out with a punch. It only took about 15 minuter or so and the old joints were in the trash. Good post about replacing the bushings. I bought a complete rebuild kit, that had all the bushings and ball joints to do both sides for around $190. Had it laser aligned and all is doing great.
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
I am taking liberty to start a thread in the FAQ section on this, since information using the search function was limited when I had to do my research on this.
If you plan to replace the factory ball joints on your Pinto, it is probably a lot more work than you might anticipate, especially if you are a semi-novice at home mechanic like myself. I was not expecting it to take so long, nor for it to require so much effort.
First off, the factory ball joints are not bolted into place like the replacements will be. From the factory, Ford riveted them into place using 3/8" diameter steel rivets with flat heads. Ford's recommendation to ball joints service, is not to service them! That is, they recommended an stressed that the ENTIRE CONTROL ARM be replaced, and after doing the work myself, I can see why. Haynes, Clymer, and Chiltons manuals will all tell you the same thing, to replace the control arm.
If you decide to go through with doing your own ball joint replacement, I would recommend replacing the control arm bushings as well as the strut lower control arm bushings as well. Since you will be under there anyway, taking it all apart, you might as well save yourself the cost of another undue alignment in the future by getting it all done at once. Just be sure to note where the control arm sits before you remove it by scribing the arm around the bolts, or even painting the bolt area before removing it, then aligning everything during reassembly. Either way, you will need an alignment in the end.
I don't have much to really point out, aside from a tip on removing the original steel rivets an easy way. Doing it this way saved me 30-45 minutes of hammering with a cold chisel.
Start by cutting an "X", or a cross, straight down into the rivet head (pictured), this degrades the structural integrity of the rivet head and makes chiseling the remainder of it off VERY easy. It took me about 15 minutes to cut off the heads of the upper control arm rivets with this method, while cutting straight through the solid head took me about an hour - hour and 15 minutes to do without this step. I used a dremel with a reinforced cutting wheel to cut the heads, and then finished up with a small cold chisel (pictured), sharpening it after cutting off the head of each bolt. I sharpen my chisels using my dad's bench grinder (pictured).
Once the head is cut off of all the rivets on one side of the ball joint, it doesn't matter which one, you can then take a drift to the center of the rivet, support the arm in a bench vice or something similar, and pound them out. Once done, the joint should split into two, with the ball joint on the top of the control arm, and the boot+retaining ring on the bottom.
The final steps would be to clean up the control arm, then install the new ball-joint, but this time using nuts and bolts. in the end, the nuts and bolts will save you a TON of work later if, if you should need to replace them at a later date.
I hope these helps someone in the future. If anyone else has something to post about ball joint repair, please post it! It would be nice to have as much info as possible, centralized and available to everyone.
