hood for a 79-80
Date: 11/30/2018 10:55 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
Date: 08/08/2017 01:44 pm
Date: 02/18/2017 04:47 pm
Date: 09/26/2019 05:31 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 03/05/2017 03:27 pm
Date: 04/28/2018 04:12 pm
Date: 10/25/2019 04:05 pm
  • Online today: 1,166
  • Guests: 484
  • Total: 484
a question on clutch cables...
Started by HighHooder, September 17, 2004, 03:56:32 PM
HighHooder
and the answer is... You can buy a BRAND NEW clutch cable for a '75 and up Pinto and it will fit either a 1.6 or a  2.0 ;D
Proud owner of a 1972 Ford Exploder
UltimatePinto
You might want to try a local marina if you have any in your area. I had a replacement cable installed into my 72 Runabout clutch cable when I put a T-5 into it. Had to make it a couple inches longer that the original. They also made up a small piece that attaches right to the tranny. If I can get my e-brake cable apart, I'll be bringing that to them to. They can work with cable up to 5/16" Can't tell you what this has to do with boats, but it worked for me.
Al
michealsich
there is not much diference between the tow the only diference if any is the ajusters some have two one on the fire wall and one on the bell houseing but it shoud work with minor ajustments
HighHooder
seeing as how mine broke the ball off of the pedal end a couple of days ago I've had to do some serious searching for a "new" cable...  does anybody know if there is any difference between a '72 cable and say a '76 cable???
this really sucks :'( gas is WAY too expensive to use the 3/4-ton as a daily driver
