Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 11/11/2019 03:38 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 02/18/2017 04:44 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 05/24/2020 08:19 am
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Date: 02/28/2018 09:37 am
71-73 Hood
Date: 12/07/2018 06:22 pm
  • Online today: 529
  • Guests: 363
  • Total: 363
Headliner Question
Started by rancheroo, February 18, 2009, 08:47:54 PM
rancheroo
Thanks fellas.  Cammer, I have a quart of metal to metak filler, but I want to cut out the rust & weld in new metal as I have 5 holes big enough for my thumb.  Putting filler on it won't stop the rust.  It may slow it down, but I don't want to go through the trouble of doing the bodywork & painting the car to have bubbles appear in the paint at a later date.
I guess I'll go real slow & try to be extra careful so I don't burn holes in the liner.  Tonight I welded up the five holes on the passenger side C-pillar that hah vinyl top trim clips in them.  Went to put my metal to metal filler on top of the ground down welds...& my brand new can is as hard as a rock...I'll exchange it.  no holes yet...
  Rick
might want to look for this stuff called labmetal, its actual metal in a can. you apply it like bondo and it can be shaped with regular body tools. works very nice. my local welding supply store carries it.
Good luck, the channel that holds the headliner above the door is barbed. And usually after age the original material is very fragile.
rancheroo
I have to weld some metal into the roof of my 74, right along the rain gutter.  I'd like to detach the headliner in the passenger side door opening & slide a metal plate in there so I don't burn up my headliner.  How do I detach the liner, just along the side so I don't destroy it while welding?
  Rick
