1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 02/10/2017 09:30 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 08/17/2022 06:27 pm
Date: 08/13/2021 10:39 am
72 pinto
Date: 06/23/2016 12:40 pm
Date: 12/13/2016 10:25 am
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
  • Online today: 583
  • Guests: 389
  • Total: 389
Sizing a motor
Started by ziegld1, February 08, 2009, 08:17:42 PM
Yes the 2.3 oil fillers are at the rear. The 2.0 oil fillers are at the front if i remember right. Also i dont think the 2.0 has a sight plug in the timing belt cover to check on cam timing without removing the cover. Can also look at the distributor. If its got electronic ignition is for sure a 2.3, if its points its probably a 2.0 but could be a 74 2.3. If it was a 1.6 the intake manifold would be on the passengers side of the car, and the 2.0 and 2.3s have the intake on the drivers side. Hope this helps.
Isn't the 2.0 oil fill the the other way around? My 2.3 and all that I have seen have it at the back corner nearest the driver's side on the valve cover.
apintonut
hmm good question i just know by looking and dont haft think about it but when i think about what come to mind is see the valve cover come to mind the 2.0 oil fill is towards the back of the valve cover MOST of the time BUT not on some Capri motors and the 2.3 oil fill is in the front of the valve cover MOST of the time the 2.0 distributor is smaller and the cap is held on with clips like a vw/ the 2.3 cap is held on with 2 screws most 2.3 the intake has a egr plate under the carb that is removable / the 2.0 carb has a smaller spread on the carb bolts and bolt to the manifold  the 2.0 is 1& 3/4 smaller in length and about 75lb lighter
hope this helps
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
 :welcome:
an easy way to identify a 2.3L motor is the oil filter location. It is usually a pretty hefty sized one that is screwed onto the block at the back of the engine towards the transmission.
ziegld1
OK I have been given a runnning motor out of a Pinto and don't know the size. How can I identify the size of the motor ? Casting number on block ? Please help thatnks. Ziegld1
