Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 02/14/2018 01:34 am
Date: 10/02/2017 02:16 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Date: 06/24/2020 06:12 am
  • Online today: 210
  • Guests: 183
  • Total: 183
V-8 swap
Started by orangekrush, February 06, 2009, 02:34:52 AM
I dont think they bolt "right" in, From what i have read there is always a little cutting involved. I would do a search on the site, im sure there is something on it here somewhere.
orangekrush
i know this gets asked alot but i have a 78 pinto and a 302/aod set from a 84 t-bird. and i want to make a hot rod!! ive also got a set of the supercomp hooker 6161 type headers (so im ahead of the game) what i need to know is if anyone makes a set of bolt in motor mounts for this swap. ive heard that the mounts from a 77-78 mustang cobra bolt right in. and so does the radiator. is that true? and ive also heard that you need to use the front coils from this car too. basically i want this to go as smoothly and quickly as possible so what parts do i not have that i need?!!! ive also heard that you can flip the tranny mount backwards and it bolts right up to a aod or c4. is this true? thanks in advance to the people that respond to my questions!! my pinto has the 2.3 and 4 speed in it now too if that helps anything.  :mad:
lifes too short to drive a boring ride!
