Date: 07/04/2017 03:26 pm
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 03/14/2020 01:52 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 09/06/2020 01:57 am
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Sunroof shade
Date: 06/19/2019 01:33 pm
Date: 04/20/2017 10:10 am
Date: 05/22/2018 02:27 pm
  • Online today: 583
  • Guests: 398
  • Total: 398
rear shocks on a wagon
Started by hobbit1games, January 25, 2009, 03:36:38 PM
5826 is the same number they gave me for my 75 wagon and they fit perfectly.
lugnut
Quote from: 71hotrodpinto on January 25, 2009, 05:16:20 PM
Ummm yah, as i said, Kragen has them through Monroe and the part # is 5826 for the sensatrac. As far as selection there isnt much. There might me others but thats all i know about.
Keep in mind that part # is for Wagons thru 1974;  '75 and up is a different part.  rockauto.com has them for about $17.50  looks like the front shocks are the same for Sed., HB and wagon all years. rockauto also has AC Delco, Sachs and KYB for some apps.  No, I'm not spamming for rockauto ;D
I just looked and the Kragen On Line price was $22.99.
http://www.partsamerica.com/ProductDetail.aspx?MfrCode=MON&MfrPartNumber=5826&PartType=50&PTSet=A
I say this "at your own risk," but I am running sedan shocks on my wagon (1973 if it matters).  On the top I used as many shock washers (2 or 3) as one can manage on the shock side and still tighten the nut.  I then used a spacer of about 3/4" on the threaded shaft at the bottom (on the shock side as well). Again, that was all I could add and still tighten the nut.
  What this effectively did was compensate for 1" the 1-1/2" of length missing from the sedan shock.  I've had them in this configuration for a number of months now and have not had any issues of bottoming out or hyperextention.  If I recall correctly in my testing it wasn't compression, but extension that was the issue.  Since I'm not too incline to "fly" like the General Lee I'm not too worried about the missing 1/2" on extention.
Again, "at your own risk."
Tom
Kragen Shucks Checker( same company different areas) all carry the Monroe Sensatrac gas shocks for the wagons, they are the only source i have found with these shocks. think they were 29.99 each shock.
hobbit1games
GO! PINTO GO!
71hotrodpinto
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
71hotrodpinto
Nope. Sorry but the wagon has specific shocks. For example the Monroe Sensa-trac has a #5819 for the sedan/runabout and a Wagon has a #5826. Looked a Kragen for that info.
Gl!
Edelbrock Airgap
Mil
hobbit1games
does the rear shocks of a runabout fit the wagon? OK i got my shocks but i don't
have any idea no how that go on
GO! PINTO GO!
