Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Date: 03/30/2021 12:29 pm
Date: 04/25/2017 12:17 pm
Date: 09/10/2018 10:41 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 04/21/2017 02:03 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
  • Online today: 502
  • Guests: 414
  • Total: 414
Replacing key in steering colum
Started by Farmboy, September 14, 2004, 08:40:33 AM
Farmboy
74 Pinto Wagon
71 Runabout (parts car)
WVBobcat77
I emailed you the pages from my Haynes manual dealing with this.  Did you get them?
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
WVBobcat77
Need to get you a Haynes manual.  Shows diagrams on how to do it.
Bill in WV
1977 Bobcat
Farmboy
   Your right r4pinto, I was kinda drunk when I read the earler post and it sounded good last night, but I need to replace the lock cylinder, I should hire the guys in the movies to do it, like gone in 60 secounds, there fast.
74 Pinto Wagon
Correct me if I'm wrong, but isn't he looking on how to replace the lock cylinder? I thought that's what he wanted replaced as the outter part just turns around in typical Ford fashion...
If not, I'm sorry I spoke.
losin sux
Starting to get a little windy here in Arkansas.  My sister lives 20 miles east of Pensacola and has decided to ride it out.  I got my Pinto from St. Petersburg between Charley and Frances hitting down there.
77 HB 2.3 C3 3.40
Farmboy
  Thank you, sounds like a good rainy day project in Wa. St.  Speaking of rain, hows the rest of the good ole US of A doing, you guy OK in the gulf coast?
74 Pinto Wagon
losin sux
Disconnect the battery ( don't wanna do the electric boogaloo)
Remove the nuts securing the steering column and lower the column out from that support bracket
Disconnect the ignition switch wire plug
Remove the nuts that hold the switch to the column
Take the actuator arm from the switch, lift it off the column studs
When installing MAKE SURE THE NEW IGNITION IS IN LOCK
Connect arm to plunger
Put the new switch on the studs and start the nuts on the studs
Move the switch up and down the column checking for the play in the arm, with the switch at the middle of the play tighten the nuts
Put the column back together
Connect the battery, say 3 "Hail Pinto full of gas", cross your fingers and give it a whirl
Hope this helps!      Steve
77 HB 2.3 C3 3.40
Farmboy
  How do you go about replacing the part where the key goes into the steering colum? My wagon, a 1974 was broken into with the pre. owner and somebody tried to steal it. They took a set of chanel locks and spun the igniton so all it does now is goes around in a circle. now its kind of a funky way to start it and I'm tired of my friends laughing at it when we go cruisin. Any help would be great!! ???
74 Pinto Wagon
