Date: 10/28/2018 08:45 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Date: 11/14/2019 04:02 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Interior Parts
Date: 08/07/2017 03:59 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 04/30/2023 04:31 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
  • Online today: 295
  • Guests: 248
  • Total: 248
starting my 2.3 project and need help to start
Started by joeykillsyou, January 19, 2009, 12:21:07 AM
Performance from a stock motor is mostly about tuning. Make sure your ignition system is in good shape (including the timing belt) and that you have a fresh fuel filter and good fuel pressure. There are things you can do to improve a stock looking motor internally such as camshaft, larger bore, valve work, etc. Or you could go "mostly stock" and add a header, and an "Offenhauser" intake manifold for a 4 barrel carb (they pop up on e-bay pretty often). There's also a neat dual 2 barrel side draft setup ( like the racer walsh setup) that will set you back about $850. Just some options.
joeykillsyou
i need help with my pinto project. i have a 77 and want to stay stock with a carb. no turbo, but then again want that extra power. for some reason i want to still keep it a carb but want to swap the engine for a draw through from a 79- 80 capri or mustang 2.3l. i have no idea why i dont want to run it fuel injected.
so my questions are
how to make my n/a stock 2.3l quick with add ons and bore ratios and gears etc...?
are the 79 -80 capri/ mustang engine worth swaping in?
