Early 2.0 engines
Date: 05/09/2018 12:45 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Front sump oil pan
Date: 01/02/2017 06:54 pm
Date: 03/17/2019 03:57 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 05/03/2024 05:37 am
Date: 09/21/2018 11:35 am
Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 11/04/2018 02:34 am
  • Online today: 489
  • Users: 1
  • Guests: 176
  • Total: 177
  • Pinto916
Speedo is off which gear to use?
Started by TIGGER, January 11, 2009, 08:42:07 PM
I drove the car to the swapmeet this morning and could tell it was better but it was hard to tell how far it was off.  I need to find one of those speed boxes.  I think I know where there is one but it is out of my way.  I guess I will need to make a special trip to check it out.
Thanks guys, I installed a 19 tooth today but I have not driven the car yet as I am changing the door seals.  The car had a 17 tooth in it.  I also have a 21 tooth in case I need it. I will let you know what I find.  According to a calculator that I found on line I need a 21 tooth.  That is if I believe that I really have 3:40's in the rear ;D
There is also a difference between automatic and manual speedo gears on Fords.
I heard that it's about 5 mph difference for each tooth. Except that I was told this by a professional GM mechanic. So what do they know?  ;D
more teeth to slow it down, about 3 mph per tooth. should be a number stamped on the end (really small) for the # of teeth and an "R" meaning it turns to the right
Lugnut is right Fords are color coded.  Fred   :)
lugnut
Quote from: dholvrsn on January 11, 2009, 09:41:02 PM
Try one with two more teeth for starters.
I agree;  if i recall, each 'tooth' change is about 5%.  Also, the gear doesn't have to be from a Pinto- I think many Ford speedo gears are the same- i remember putting one from a '60s Mustang into an '80s pickup.  Years ago I grabbed an assortment at the wrecking yard. I think they are color coded too (but i may be thinking of Mopar)
The speedometer is off on my 78 CW it is about 10 mph too fast as near as I can tell.  Do I go up in teeth to slow it down or do I go down in teeth?
