1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 02/18/2017 05:55 pm
Date: 03/16/2017 10:00 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
FREE PARTS!!
Date: 01/10/2017 02:38 pm
Date: 11/11/2019 03:38 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 08/26/2018 06:35 pm
  • Online today: 1,166
  • Guests: 486
  • Total: 486
Racer Walsh Products
Started by hoots, September 13, 2004, 05:01:16 PM
bossmav
Hoots, maybe I can help point you in the right direction.
I know I guy who makes subframe connectors for Mavericks and Comets, now he has a Maverick to go by BUT I'm sure if you had all the mesurements he could make what you need.
He has made hundreds for the Maverick/Comets guys and we all love them.
Here is the contact info: Dan Starnes
http://mmb.maverick.to/member.php?u=47
If the link above doesn't work go to www.Maverick.to and do a search for Dan Starnes
Hope the helps.
Terry Gates
AKA Bossmav
straw boss
I can't give them a good recommendation either.  They burned me on the core charge for a turbo several years ago.  Also, there have been several people on the Turboford board that are not happy with Racer Walsh.
hoots
Racer Walsh got the subframe connectors back and charged me a restocking fee of 15.00. THEY sent the wrong parts and I take the finacial hit. With shipping both ways and this charge...I should have kept them. Needless to say they won't get any more of my business!!
hoots
They took 1/8" off both sides and had to put a 45 degree angle at the top so they would fit in the U shaped shakle. The oval at the top also had to be trimmed. Cost me another $80.00. I sent the subframe connectors bad to Racer, still waiting to see what happens with that. Hopefully there won't be any problems.
I bought two sets of their lowering blocks and didn't seem to have any problems with either set.  They both were a tight fit but a little cleaning to the brackets seemed to do the trick.  How much machining did you have to do to them?
There has been a lot of trouble with Walsh since they sold their company to a bunch of real jerks. Beware!!!!  After 20+ years of useing them, I will never do it again.
bricker4864
I don't have any subframe connectors, but I have had a similar experience with walsh. Good Luck  :-\
hoots
Just received some lowering blocks and sub frame connectors from Racer Walsh. The lowering blocks were a close fit, but still had to have them machined. They were too wide and the top elevated oval wasn't even close to seating in it's spot.
The subframe connectors aren't even close to fitting my wagon. They have sent me an RMA for the return, but this has  not been a pleasant ordeal.  :-\
Has anyone found subframe connectors for a wagon, doesn't matter if the are bolt on or welded type.
