Need Clutch & Brake Pedal
Date: 12/23/2016 06:16 pm
pinto for sale
Date: 09/11/2016 09:47 pm
v8 springs
Date: 05/07/2017 04:46 pm
Date: 04/14/2023 06:15 am
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Date: 05/19/2018 04:56 pm
Date: 12/20/2016 10:47 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 10/10/2019 09:42 pm
  • Online today: 506
  • Guests: 226
  • Total: 226
4 lug to 5 lug swaps
Started by Carolina Boy, January 04, 2009, 06:06:38 PM
I don't mean to sound rude, but a 1997 Granada? I didn't realize they made the car that late. I thought it stopped in the early 80s. Or do you mean 77?
pintoperformance
I switched my front rotors over using a SPEEDWAY MOTORS kit that converts to a five lug using new rotor kit.  Also I converted my rear to five lugs using a rear end out of a 1997 Ford Granada --8.7 rear end slides right under the car and bolts right up...
Hey Mike I am kinda new to the pinto world i have been searching for alot different stuff and ways to do things to this project, i checked out the sight you posted and wow, its purty sweet thanks for the tip!! ;D
Mike Modified
I build street rods and have installed 35-40 perhaps Mustang II/Pinto "style" front ends into early Fords and Chevys.
When doing 11" Granada rotors, I use Chassis Engineering part no AU-2045 http://chassisengineeringinc.com/page69.html (second item down) that adapts 80's Mustang and Thunderbird calipers to the Pinto spindles.  I prefer to use Ford engineered parts if possible, but I really dislike the GM metric calipers.
You did not say what year Pinto you had.  The rjays.com site is set up for 74-78
Mustang II which is the same as 74-80 Pinto's.  So if you have the later model Pinto things should just bolt together.  If you have 71-73 Pinto, the TurboPinto72 thread is the one to follow (you will need early disc spindles).
If you have a 74-80 Pinto and just want to go to 5 lug, rjays, Speedway, and others sell the Granada rotors cut down to 9-1/4" to bolt on with the stock calipers (per their ads).  This would be a easy way to go.
http://www.speedwaymotors.com/5-Bolt-Mustang-II-Rotors,1964.html
http://rjays.com/Brakes/MII-Brakes-01.htm
Glad to help and thanks for that link. ( i needed to get set up for a 5 lug swap myself)  :smile:
that is a good price, You can do it your self for under 100 with the new granada rotors but you will have to put some work in it.
 :amazed: :o :o ;D :surprised: :surprised:
Hey thanks for the info. I did as you said and did a seach of the Pinto board and lo and behold it was Turbo's thread. He mentioned a site called rjays.com. I pulled up the site. They have a complete setup for the stock Pinto spindle. Rotors, brake and bracket for less than $250. You guys are great and I'm sure glad I found this wonderful club.
Carolina Boy :)
I think it was turbopinto72 that posted this and it works well, i just did my 71. I had to get disc spindles from a 72, then bought the disc brackets from ebay. The brackets have to be modified a little as you can read in his post. I bought 75 Granada rotors and wheel bearings, found some GM metric calipers in the junk yard off of a 78 Monte carlo. It is not a direct bolt in but if you have welder it is not bad. you will have to do a little clearance work on the upper controll arms but it is very good a cheap swap.
Here is the thread you need to read http://www.fordpinto.com/smf/index.php?topic=1103.0
There have been many posts on it. from what i can garner from the information there is no Direct bolt in from a Granada or 5 lug mustangs/mavricks. you have to get the disc drilled out or you have to get an aftermarket kit for the pinto. I would Search on the site for it and see what you can learn that way.
A mechanic freind of a freind told me that the Granada disc brake setup can be used on a Pinto. :amazed: Just remove the Pinto disc setup spindle and all, and bolt the Granada spindle and brake set right back in. This sound almost to good to be true. :surprised: Is he right?
Surprised in NC
