Date: 08/06/2021 02:23 pm
77 pinto
Date: 08/22/2017 06:31 pm
Date: 02/27/2017 10:10 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 07/03/2025 04:35 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
Date: 03/16/2017 10:00 pm
  • Online today: 452
  • Guests: 357
  • Total: 357
AOD Transmission install
Started by Norman Bagi, December 03, 2008, 07:59:50 PM
hoots
I have a 302/AOD installed in my 76 wagon. Had to customize the tranny mount, but it's in. The drive shaft I'm using was also used when I had a C4, it fit right in.
302Pinto
I have a '79 pinto with a 302 with the AOD. It does fit but the front end has been extended out by 4 or 5 inches. I'm not sure if the drive shaft is the original or if you have to find a shorter one. So, just in case you're wondering, it does fit.
i I am working on this install with a 3.8, if you use the 2.3l left side Long mounts as a friend did with his 77 CW and 302 combo you might get the clearance you need. i do say might.
This is for a 302 Pinto, I just want to know if anyone has accomplished this.  The reason is obvious, better highway mileage with the .67 overdrive gear.  if this hasn't been done, I may go with a gear vendors, but that is more than I want to spend.   :read: Thanks.
turbo74pinto
Quote from: map351 on December 04, 2008, 07:58:27 AM
I have a AOD in my 40 Ford i don't think it's gonna fit in a pinto tunnel..
i agree, thats a pretty big bell compaired to pinto stuff.  but for what its worth stinger makes an addapter for ford v8 trannys to 2.3s.
bob
www.stinger-performance.com
map351
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Who here has done an AOD transmission change out?  Checking in previous posts, there are conflicting statements on the difficulty of this install, so I am ins earch of the truth.  Does anyone have any pictures or details.  Please reply only if you have the information.  Thank You.
