looking for parts
Date: 06/19/2020 02:32 pm
Date: 06/24/2020 06:12 am
Date: 10/03/2018 10:46 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 11/02/2019 10:25 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
looking for parts
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
  • Online today: 586
Question About cowl
Started by BlueGoldPinto, September 08, 2004, 04:15:03 PM
BlueGoldPinto
Hey, does anybody know how to remove the dash pad on my 78'? I need to getinto the heater core, and possibly remove the heater plenum etc. to see how badly it's rusted. Whats the trick?
BlueGoldPinto
Well, if that's what I have to do, that's what I have to do then. I was looking at the hood and hinges and thought that it looked like if you took the hood, and the plate the hinges are connected too and unbolted them,it looked like you could get your hand into a pretty good sized hole, because I saw that there was a gasket there and wondered if that was how you got in there. But I diid'nt wanna go to all the bother and risk of disalining the hood just to be disapointed. Well, I need new weather-stripping anyways, but removing that fender will be no easy job. I think I'm gonna need some help, and a lot more money. :'( Thanks to both who replied.
73pinto
If water is leaking you already have a rust hole and it will only get worse until you fix it.  In order to do so, you'll have to pull the hood and hinges, fenders, and windsheild.   Then you'll have to get a spot-welld cutter and cut the spot welds to pull the cowl off.  When you find the rust hole(s) you may be able to grind the rust away and fill the holes with seam sealer.  If they're too big to fill your only other alternative is to weld patches in.
This is a big problem with mustangs and mavericks.  Sadly, there is no easy fix.
-Harry
Stock 73 2.0/4spd 3:40 maximum slip, cd player, pop-out quarter glass.  Soon to be slight performance 2.0/5spd and much more...
Scott Hamilton
The only way I know to clean, fix refinish the inside of the cowl without cutting is to remove the hood hinges & work through the holes. Otherwise, you will need to do some cutting, fixing & welding to do it right.
This has been my experience at least, is there another way?
BlueGoldPinto
Common, Someone has got to know something about this!!! Have'nt any of you ever removed your cowl before??? Do you have to remove your dash to get at it? I highly doubt that Ford changed the installation process on their cowls from 71 to 78. A little help here, please?
BlueGoldPinto
 My drain Holes are plugged on my 1978 Ford Pinto Runabout, and so now water is now leaking in through the dash, (or possibly the heater core) How can I remove my cowl to clean all of the pine needles and such out because I think it's welded on. I really don''t want to remove my fenders to clean the rust out. I put an airhose to the cowl, and cleared things out a little bit so its not leaking as badly, but its still leaking. Mabye something is rusted out from it being plugged so long?????? If I have to get at the heater core to remove it, how do I do that??? PLEASE HELP!!!!!! IT LOOKS LIKE RAIN!
