Date: 07/30/2018 04:32 pm
Date: 12/09/2018 11:35 pm
Need 72 pinto parts!
Date: 06/14/2019 01:40 pm
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
Date: 09/12/2018 04:07 pm
Date: 05/15/2022 11:36 am
Date: 10/31/2018 12:04 pm
Date: 10/15/2017 10:03 am
Date: 09/01/2017 07:52 am
  • Online today: 533
  • Users: 1
  • Guests: 477
  • Total: 478
power steering pump
Started by miked1989, November 28, 2008, 07:53:08 PM
that is the same type as my 76 it was/is a metal dip stick about 5 in long.
miked1989
77 pinto first car!
Not a problem.. It's just a matter of a mid year change on the car. They changed pump styles mid year.
miked1989
ill get back to you on the year i have to get down to the spot were i work on my car. bout 30min drive
77 pinto first car!
I'm not too sure on the plate... With the dipstick is it a small hole or is it a bigger hole? The one with plastic had the dipstick built into the cap, like the 80's & 90's Fords. Is yours an early 77 (built before 6/77) or a late 77 (after 6/77)
miked1989
yea the dipstick is missing I'm not sure about weather it was plastic or metal. the plate is on the pump right behind the drive pulley.
77 pinto first car!
What plate are you referring to? for the bolts your best bet is to take the pump  off so you can extract the broken bolt. Then you can use the broken piece to identify the thread size to get replacements. The hard part will be getting the right length since you don't have any for it. Are you referring to the pressure & return hoses? If so you can get those from Advance Auto. Is the dipstick missing? If so is it a metal or plastic? There were two different models. One with metal reservoir & one with plastic. The dipsticks are not interchangeable.
miked1989
i have a broken bolt in the pump and have lost the other two bolts for it. were do i look to replace the whole pump dipstick and hose that would addapt to it? it has a plate that is on it. is there a replacement plate or am i kinda out of luck with that pump?  the 2.3l 77 wagon
77 pinto first car!
