Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Clutch Cable Needed
Date: 04/03/2017 11:03 pm
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 10/25/2019 03:30 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
  • Online today: 529
  • Guests: 453
  • Total: 453
Can you get boots for hood hinges
Started by smallfryefarm, November 25, 2008, 08:25:13 AM
thanks i will do a search, and check on the fox body. shame of it is these things were still intact till i had to pull them out and i destroyed them.
Those boots seem to allways be cracked and turn into junk the first time you pull the hinge out. It would be great to have a source to get re-pops.
Do a search.  I believe someone posted that the foxbody Mustangs use the same or a similar boot.  Good luck on your cowl repairs.
Took my hood hinges out to get a good look at the cowl hoping not to have to do any repairs, but as suspected need to fix some stuff in their, took the heater box out shouldn't be to hard to fix, but the rubber boots behind the hinges are bad. Has any one else tried to find these? I haven't called the ford store yet but don't figure they stock this any more.
