  • Online today: 899
  • Guests: 482
  • Total: 482
'72 2000cc motor mods
Started by jimknightford@yaho, September 08, 2004, 03:41:34 AM
175 HP!  Lots of luck. Jerry Walsh once told me that in all his dealing with a 2.0L, he had only seen a couple make 175 HP. The head is pure junk with the way the intake ports turn in the head before the valve head. Only high HP motors I ever saw were ones with the intake ports welded up and moved up on the head. That cost over a grand in 1972. Again, lots of luck.
Scott Hamilton
Excellent, I too have a 2000 I want to nudge...
THANKS!
 Ok, I will do a full list of mods including some part numbers and spec's. It will take a few days to compile but it will be worth it. I will be posting it in the FAQ section under the heading, HiPo 2000.
allfordmark
I have a similar situation.  I think that the 2.0 with 150-160 hp would be a lot of fun to drive.  My 72 definitely could use help in the breathing department. I want to continue to run on the street and keep it light.  I am not going to run at the strip.  i would be interested in that list as well.
'66 Mustang
'72 Pinto
'50 F-1 1/2 ton Pick-up
Jim, I emaild you off list with some thoughts and ideas. As far as gearing, lets see what combo you will use before we get into that.
jimknightford@yaho
To Brad, TurboPinto'72,  My name is Jim knight, I'm a fellow Pinto enthusiest and all around Ford person. I have aquired a '72 runabout and want to turn it into a hot street/strip car.  I need some advise on how to build the 2.0 and turn it into a hobby racer (so I can give those kids in their honda cars some greif) I'm 46y/o and have experiance in engine building, mostly Ford V-8's VW's and some british junk but this is my first 2.0.  I was wondering if you had a good recipe to make a normally aspirated motor that will run on pump premium.  I know the bottom end in these motors are stout and the prep I can do but what do I need as far as head work-valves, cams, induction, exhaust etc. to reach my goal which is ~175hp?  I know it can be done but what combination of parts do I need?  I dont want to buy a bunch of parts and hope they work so I hoping you can lend some advise.  I plan to run a C-4 trans (hips are bad cant clutch anymore) and a 8 inch rear with either one of 3 ratios-3:73,3:90 or 4:11's  What do you think?  My e-mail is jimknightford@yahoo.com  Thanks, Jim
