Date: 02/05/2017 09:45 am
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
windshield
Date: 04/14/2018 08:53 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 09/12/2018 04:07 pm
Date: 06/07/2021 08:14 pm
Date: 11/11/2019 04:49 pm
  • Online today: 452
  • Guests: 361
  • Total: 361
COIL SPRING QUESTION
Started by smallfryefarm, November 21, 2008, 09:01:18 AM
When I put the V8 in my '71 I used V6 springs and cut out one full coil, my car is lowered 2" so if you are going for stock ride height it should be real close with the full coil.
Tommy, Bill thanks for the input this V8 pinto is all new to me.
The ones I put in my V8 Pinto were new ones that I was told were for a "Mustang II V8", but I had no way to verify that. I did measure and compair them to the stock springs, and they were beefier. I put them in but the car sat too high due to MII's being heavier. I cut 3/4 of a coil off (that made them easy to work with), but I should have taken about a full coil off, maybe a little more. I left them in figuring it would settle a little, but it did not.
TOMMYS
I'M NOT SURE WHAT WEIGHT RATING THEY HAVE,HOWEVER,I USED NEW V6 PINTO WAGON SPRINGS IN MY 80 AND SITS NICELY W/302 IN IT.CHECK MY PICS TO SEE.I ALSO HAVE 15" WHEELS AND TIRES ON FRONT.THANKS TOMMYS
Does any one know what the front coil spring rate is on the 74 mustang II V8. I am thinking 375 lbs. I need to get some springs for my ride that will hold up the 302.  Do you recommend maybe going up to 400 or 425lbs to help the handling
