  • Online today: 210
  • Guests: 197
  • Total: 197
Giages in radio slot?
Started by Reed, November 14, 2008, 12:17:56 AM
Reed
Nice!  Unfortunately, I had a radio.  I think I will just screw a triple guage housing in to the screws for the radio bezel.
I cut the back off the factory "radio delete" glove box and mounted a standard 3 gauge plate there. Changed my mind later. There is a gap around the gauges in mine.
Before
Now
Maybe install the later factory ones; thats what I did.
My 73 has gauges in the radio opening.  They will be moving to a pilar pod when I have the time.  They are just mounted in one of those standard three gauge brackets.  It is not the cleanest b ut it works.
Reed
I have seen some of you guys put three guages where the radio used to be.  How did you do this?  I have removed the old deck and installed an underdahs deck, and I would like to use the radio hole for some guages.
Does anyone have a template they could scan so I could copy it?  How did people mount and design the holder for the guages?
Detailed pictures would be great.  Thanks.
