2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 02/14/2018 01:34 am
Date: 05/18/2020 10:22 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Beautiful 1980 Pinto
Date: 04/13/2020 11:53 am
Date: 02/18/2017 04:44 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 04/28/2018 04:12 pm
Date: 07/30/2018 04:32 pm
  • Online today: 445
  • Guests: 210
  • Total: 210
'71 2.0L - Dual Carb and Oil Separator Question
Started by Nakturnal99, November 11, 2008, 05:35:31 PM
72pair
Unless you just want the 2 carb look, polish that fp-1 and put it on the shelf. The stock intake with a little grinding in the plenum and port match, along with a rejetted 5200 holley/weber performs much better. Just my experience. I think i used 6 cyl chevy rochesters (recommended at the time). The fuel line was a simple T-fitting from the stock line to both carbs. Good luck!! JT
Nakturnal99
I am looking to install a dual  carb setup using an edelbrock fp-1(2820) intake and have been unable to locate an information on installation of this intake in regards to fuel lines and other hoses.  I have also noticed that my oil separator has come apart from the block - will i need this with the swap?  If so where can I locate one?  Thanks for your time and help.
