A.c. alternator hrackets
Date: 09/03/2017 12:11 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 04/25/2017 12:17 pm
Radiator
Date: 05/27/2018 06:07 am
Date: 04/10/2017 07:30 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
  • Online today: 600
  • Guests: 261
  • Total: 261
Foggy rear window!
Started by dave1987, October 10, 2008, 07:19:39 PM
Thank you PintoDriver! I will definitely be looking into purchasing a roll of this to properly replace my trunk seal!
Today I removed the chrome from around the rear window, then took some clear RTV silicon sealant for windshields and pumped it in between the window and where the outside of the seal mate. It looks like it should seal the rear window pretty well, but we shall see how well it does when it gets time to fog up again!
PintoDriver
JCW has universal seals that will work great on your ride!  Here's the link if you are interested....pretty cheap!!
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000225947/mediaCode-ZX/appId-100000225947/Pr-p_CATENTRY_ID:100000225947
$19.99
1980 Cruising Wagon
1980 All Glass Hatchback
agreed.  I need new door seals, channels and "lips" too, and a trunk seal. Just seem to be last on the list since it doesn't rain much here in New Mexico.
Chuck :afro:
Reed
There's alot of that going around these days.... :embarassed:
I know I have leaks. I need to replace the floorpan on the driver's side, but before that I need to replace my windshield gasket.
Then there's the trunk seal, and the rear window seal, and the door seals too.
There's a lot that needs done for seals, but no money to do it. :(
agreed, find the leak and fix it so you don't end up with a rust problem
PintoDriver
Definitely a leak some where
1980 Cruising Wagon
And try Rain-X, I had a problem with my defroster last winter, and my windshield fogged on the inside, used Rain-X inside and out and that helped some, Cheap TEMPORARY fix.
Reed
In my experience this is caused by a water leak somewhere.  Short term, leave your vents open and the window down a crack.  Long term, find that leak.
It's snowing here in Boise Idaho!!!!!
My rear window is terribly fogged and I'm wondering if anyone else has had this problem with their Pinto.
I can't remember how I got by with it last winter, but I know I did. Cracking the windows about 1/2 inch? Leaving the vents open? Any tips?
