Oddsnends
Date: 12/20/2016 10:52 am
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
Bumpers
Date: 07/06/2018 04:47 pm
Date: 07/04/2022 07:55 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
Date: 12/20/2016 10:47 pm
Deluxe Steering Wheel
Date: 10/16/2017 08:13 am
Date: 06/19/2018 03:58 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 481
  • Guests: 243
  • Total: 243
Dual door switches
Started by dave1987, October 10, 2008, 02:48:32 AM
I know that the door SWITCH itself is the same on the MII and the Pintos/Bobcats, however the wiring harness may be different (could very likely be the same though!).
You don't exactly need the wiring harness to complete this modification. I have an extra switch pigtail and I could have technically just added two longer wires to it, rand them under the dash to the driver's side swith and tapped into the Blue/Black and Green wires. It is nice having the harness though, for restoration reasons.
I'll have to put that on my projects list!  Also have a 78 sedan with no switch on the passenger side.  Will mustang II parts provide the same results?  The two pintos in the u-pull-it here don't have switches on the right either, but there are a couple mustang II's there.
Awesome! I got the switch wired up in parallel to the driver's side switch and it's working great! I took the wiring harness that I pulled from the Bobcat today and used that so it comes out looking nearly stock, aside from where I tapped into the wires on the existing switch.
Thank you to everyone and their comments!
That would be wiring them parallel.
Well my dad and me went to the yard today and behold! The Bobcat that I have been stripping down has a switch on the passenger's side!
I pulled the switch and the wiring harness for it that runs back to the tailgate, as well as the harness that runs along under the dash.
Now the Bobcat had the connector above the glove box that oldkayaker is talking about, and it is a 77. Mine however, has no trace of this connector anywhere under my dash. I pulled my gauges, radio and glove box insert all out to try and find it but there isn't anything on my 78 Sedan!
So my new question is, would it be possible to wire the switches in series, so that when either door is open (closing the switch), the light is on?
I do not know what year Pinto you have.  According to wiring diagrams (71 & 77) for the RH dome light switch, there should be a light green with yellow tracer wire from a always hot fuse and a black with light blue tracer wire from the headlight switch (also connects to to the dome light and LH switch) located on the right side.  The 71 & 77 diagrams indicate that these two wires go to a connector located in the dash above the glove box.  Just extend these two wires to your new right hand door switch.  Make sure your new switch is the type that connects two isolated wires together (like the left hand switch).  Some after market door switches will ground a wire which would cause a short in the Pinto wiring..
Nothing! There isn't any wiring on that side of the car at all that is visible, even under the dash (with an exception of the antenna wire).
You may want to pull the kick panel off and see if the plug is there already,  I would find it hard to believe if Ford built two different harnesses just for the dome lamp.  But I do not know for sure so please let us know what you find.
I was wondering if it is at all possible to wire up a second door switch for my passenger's side door so that the dome light comes on when either door is opened.
I have the switch, but I have no clue how to wire it up so it operates just like the driver's side door, but so that both doors are independently operating the dome light.
