Pinto Wagon
Date: 05/25/2018 01:50 pm
1972 Rallye wagon rebuild
Date: 11/14/2020 07:31 pm
Date: 10/25/2019 03:30 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Date: 02/26/2017 03:22 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 07/01/2019 12:23 pm
Date: 06/22/2017 07:19 am
  • Online today: 577
  • Guests: 456
  • Total: 456
starting circuit in 2.3 liter, 1980 pinto
Started by jimhammann, October 04, 2008, 05:15:02 PM
The ignition system has a by pass circuit that only works while the key is in the start position.  It allows the motor to start on a true 12 V when the engine is running the voltage to the coil is only 7.5 if I remember correctly.
The voltage is reduced with a resistor wire to the coil.
If your running circuit fails you can start the car but it will quit when the keys released.
This could be you problem honestly.
I would have the Module tested and check voltage from the switch.
Best of Luck
FrankBoss
earthquake
I had the same issue with my 80 wagon.It turned out the ignition switch was bad.
Quote from: 71pintoracer on October 05, 2008, 08:06:45 AM
When you say it won't start, do you mean it won't crank at all, or it cranks normaly but won't fire and then tries to kick over when you let off the key? If it is a no crank, I agree w/ 77turbo. If it is a crank w/ no fire, you need an ignition module.
The ones I talked about did crank. They all seemed to 'catch' for a second as the key was released.
I agree with 71PR about the IM.
IF your car has never been messed with I am willing to bet you have a issue with the ignition switch.
Could be adjusted wrong, have come loose from its mounts, have a loose connection, or could be pulling apart.
There is a cut off to all power BUT the igintion and starter relay when the key is turned to "START". When you release and it goes to "RUN", it feeds power to the igintion from a different source in the switch. If the switch is worn or bad, it will not make the contact on the "START" or the "RUN" power feed or both, and sometimes it just makes contact when you are turning the key to "OFF". I have had a few like that, and two T-Bird T/Cs as well. The T/Cs just needed a zip-tie on the switch.
Welcome.
jimhammann
I have a 1980 2.3 liter engine pinto that is having trouble starting.  When it fails to start, and you release the key and turn it to off, it seems as if it want to start.  Is there some type of relay system? in the start/run process?  Help!
