Date: 06/30/2018 09:48 am
Date: 04/15/2017 05:14 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
73 Caliper Retaining Key
Date: 10/28/2021 07:49 am
Hatch needed
Date: 09/10/2017 09:16 pm
convert to stick
Date: 05/19/2018 09:26 pm
Date: 10/01/2020 02:00 pm
Front grill for '72
Date: 03/02/2022 12:09 pm
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
  • Online today: 367
  • Guests: 143
  • Total: 143
Sport or Rally gauge set?
Started by perce111, August 23, 2004, 12:04:09 AM
wagonmaster
In '79/'80, the Sports Gauge package was available as an option and came standard on some packages, such as the Cruising Wagon. r4pinto was correct. The '78 and earlier style dash pad was used with the Sports Gauge package. It's a fairly easy swap to do, but try to get the plugs and pigtails for the cluster and gauge panel when you find them. It will make your life much easier!!
Brien - wagonmaster
'85 LTD LX
'85 LTD Squire wagon
I shoulda mentioned it's located in the following section: Your Pinto, Sedans Runabouts, & Wagons
His post is all caps. If you go to My Pinto you will see the ugly green thing I call my Pinto..
Hope this helps
Unless I am mistaken there was a Ralley option for 79-80 Pintos... Also unless I am mistaken the Ralley had a different dash setup, that was shaped like the earlier Pinto's unlike the squared off dashes of 79-80 models.
What you might want to do is go the the post by Pintoman titled MY PINTO
perce111
Hi Guys.....new here
Did the 1979 Pinto have a sport or rally gauge cluster....one that included a tach?
I know that over the years they offered the extra three gauges, oil-water-amps, and some of the early years  had the tach option.
Or if they didn't offer it in the 79/80 models will the early gauge cluster fit?
Thanx for the help
