Date: 01/28/2021 03:49 pm
Date: 02/04/2018 08:26 am
Date: 11/11/2019 04:49 pm
Pinto for sale
Date: 04/19/2017 10:15 am
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Date: 10/26/2020 03:24 pm
Date: 07/08/2017 08:25 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
  • Online today: 489
  • Guests: 223
  • Total: 223
Carb. Assistance needed
Started by fastfred, October 03, 2008, 04:16:13 PM
fastfred
Thanks for the reply.
I will check out the hose, if it exists.
Thanks .. Fred
Reed
Yes, the carb has a water heated automatic choke.  You should have a heater hose running over to the carb and then to the manifold.  If you don't, then you should post a picture so we can figure out what hhas been done to the carb.
fastfred
Thanks for the help.
I assume the carb has a automatic choke as there is nothing on the dash to operate it?
Where can I get a carb rebuild kit?
thanks
PintoDriver
A rebuild kit should cost around $30 and will come with all of the correct measurements for the leakage. On a car this old, you can never go wrong in rebuilding the carb. It's pretty easy and the results are amazing!
For example, I bought an old dodge truck for $300 because the owner couldn't get it to run. I rebuilt the carb with a $15 kit, and have been driving this truck for 3 years now! Runs better than a new truck!!
Good Luck.
1980 Cruising Wagon
1980 All Glass Hatchback
Reed
Actually, the Holley 5200 is a mechanical secondary carb.  The secondaries are controlled by a mechanical linkage that connects to the throttle linkage on the primary.  When the motor is warmed up, the secondary opens when the primary reaches about 30 degrees of being open.  It is important to note that the opening of the secondary is also controlled by the choke.  If the choke is still closed, or if the motor is still cold, the secondary will not open.  Once the motor warms up, the secondary begins to operate.
Try driving the car around to get the motor good and warm, then pull the air cleaner and watch the throttle blades.  I bet that if the motor is totally warmed up you will see the secondary throttle blade open fully.
Of course, this assumes that the stock choke system is intact and functioning.  At this point in a cars life there is no telling what prior owners or mechanics have done to the carb.  Most mechanics (especially these days) don't knwo much about carbs, much less the Holley 5200.
fastfred
I have taken some adjustment on the secondary vale so that it opens a bit earlier.
The idea is to see if it gets more gas to the motor for more acceleration.  Have not had a chance to see if it works as yet.
Has anyone tried this before?
Thanks
woodie
 check your throttle cable from your gas pedal It may have stretched over the years.  Have someone hold the gas pedal to the floor look down the carb  then with the pedal still to the floor see if the linkage will open any more at the carb with the motor off  some were on this site you will find more info on this good luck
watch this
The little Holley/Weber 5200 two barrel carb you have is similar to many standard four barrel carbs in that it has primary and secondary sides.  The secondary side is vacuum operated, which, in a nutshell, means that the airflow required by the engine will decide how much the secondary opens.  If it is not running, it will only open a little way.  You can double check to see if it has full ability to open by moving it by hand (physically touching the butterfly) with the engine NOT RUNNING.
Hope this helps!
I still suspect the carb may need to be rebuilt and properly tuned.
--Doug
**UPDATE**
Well, it looks like I may be mistaken, but that often happens when you can't remember and you get info from an internet source in the meantime.  I read a bit on the 5200 here: http://www.surpluselectron.com/aaron/holley.htm and they have a section talking about how to adjust the vacuum op secondaries by replacing the spring with a different rated one.  But as I re-read the article, they may have been talking more towards the Chrysler products that had this carb.  The 5200 has been offered on many different vehicles throughout many years.  Even the Pinto ones seemed to vary from year to year.
fastfred
Hi Folks,
I posted an issue about slowish acceleration on my 2.3 motor. Got some help, thanks.
On removing to air filter and looking down into the carb it seems that the drivers side valve opens and pumps gas okay but the other side valve only opens when the other side is almost fully open and can only open about half its possible maximum.
Is this okay? I thought maybe it isn't getting enough gas for maximum acceleration because of this?
Your replies would be helpful.
Thanks  Fred
