Date: 04/10/2017 07:30 pm
Date: 07/30/2020 11:45 am
Date: 07/20/2018 03:00 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 04/20/2017 10:10 am
Date: 02/05/2020 11:06 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
need 1978 pinto guage cluster
Date: 03/07/2021 07:35 am
1980 hood needed
Date: 04/23/2020 10:41 pm
  • Online today: 600
  • Guests: 540
  • Total: 540
efi ford
Started by pintoracer02, October 03, 2008, 03:44:01 PM
map351
Just about all the throttle body injected fords have adjustable regulators just pop the little cap off the top the adj screw is under the cap.
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
CHEAPRACER
  According to the Autozone web site, the 5.0 and the 2.3 take the same regulator, so I wood start looking for the more common 5.0 one with the aftermarket guys.
  I used to own a Mallory and the adjustment part affected the high side with the vacuum hose disconnected so I kinda confused how this will only repair your idle problem.
http://www.eautoworks.com/product-AEM-118156.htmThis is a Universal I believe. I do not know if it works for a Fuel injected System but it might. Most Efi systems run 30+ psi
And there is this one as well. this is an EFI based one but its more Costly
http://store.titanmotorsports.com/bpeefiadfupr1.html
I would look at Jegs perhaps Checkers Performance department. Else you might have to Adapt one for another year frame or a larger motor.
pintoracer02
any body know where i can find an adjustable fuel pressure regulator for a fuel injected 2.3 in an 89 mustang? I put a cam in my mustang and since it doesn't have much vacuum at idle it is running super rich.
Bass Ackwards
