78-80 Windshield
Date: 10/29/2021 03:11 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Date: 11/11/2019 04:49 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 10/24/2019 01:43 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 02/11/2020 12:09 am
Date: 10/10/2019 09:42 pm
  • Online today: 529
  • Guests: 460
  • Total: 460
Disdabling deceleration valve and vacuum retard on 71 2.0 motor
Started by Reed, October 02, 2008, 02:39:52 PM
Reed
Thanks for the invite but I am slammed with work this weekend.  I won't be able to make it out.
The vacuum advance pod is hooked to a ported source on the carb but the vacuum retard pod is hooked straight to manifold vacuum.  I haven't had much time to investigate it, but I want to get out there and pot the timing curve and see exactly at what vacuum the advance pod kicks in and also how fast it advances.  I am worried that if i just disconnect the retard pod the advance pod will come in too early and too fast.  But I need to go out and actually test it.
Thanks!
pintoman2.0
Hey Reed,
Do you have the vacuum hooked to manifold or ported. It makes a difference because the ported has 0 in/hg at idle or cruise. It only has vac under acceleration. I talked to apintonut tonight and I guess my cutting party is off. You can still come over if you want, find out where I live and what I've got.
P
Reed
Thanks!  I will disconnect it and cap the fitting on the intake with a nipple, but use the fitting later for a vacuum guage.   ;D
IIRC the retard side was for emission control, it won't affect the advance side. Take the hose off and put a BB or a ball bearing in it and hook it back up.
Reed
Hey, thanks!  How about the vacuum retard on the distributor?  If I just disconnect it from the diaphragm and plug the line will the vacuum advancecome in too quickly?
map351
Take the valve off put a penny under the valve bolt it back together, it's fixed..
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
take the 'decel' (deceleration valve) valve off at the intake manifold, tap the hole into the decel valve to (IIRC) 3/8 pipe insert a socket head (allen head) plug flush and reinstall the decel valve.  eliminates a potential vacuum leak and helps the engine rpm settle back down to idle after acceleration and between shifts
Reed
Hey gang.  I havre been driving my 71 Pinto more lately and i am not happy with the performance and gas mileage it is getting.  Mileage seems to be about 20-25 MPG mixed highway/city driving, and it seems to have a lag on acceleration.
Right now the motor is bone stock.  I would like to disable the deceleration valve and the vacuum retard on the distributor.  Can i just disconnect the hose going to the vacuum retard pod on the dist?  How do I remove/disable the deceleration valve?
Thanks!
