Date: 01/28/2017 12:30 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Pinto hubcap
Date: 01/07/2017 08:40 pm
Date: 02/21/2017 06:29 am
Date: 05/13/2021 05:33 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
pro stock front end
Date: 06/28/2019 07:43 pm
  • Online today: 176
  • Guests: 134
  • Total: 134
vacuum advance
Started by nollid, September 29, 2008, 08:11:13 AM
lencost
While I have not seen alot of re-manufactured distributors the ones that I have seen in person did not have new vacuum advances. Thy probably work however thy may not work for very long, and you may be right back to the same place you are now. As far as single or duel types it would depend on how origanal you want your engine to look. The duel type will retard the timing under certain operating condishons be careful where thy are plugged into.
Leonard
1975 Wagon 8" C4 2.8 V6
nollid
i thinkk i am just gonna buy the whole distributer set up since it is only sixty.
but what you be better a single or dual advance?
thanks
1974 pinto runabout
1971 pinto
1971 wrecked pinto
lencost
I would try to find a dealer near you that will give you a copy of the page out of the Standard catalog, you might find one that will give you the amount of advance that will give you the best fuel economy. I will PM you with my cell#.
nollid
hey thanks     but do you have a link or something when i put it into google i only get standard motor products.
1974 pinto runabout
1971 pinto
1971 wrecked pinto
lencost
Standard ignition products has a large assortment of vacuum advance units, and they look like the factory units. Check the manifold vacuum at the speed you cruise at most of the time, and do this on a fairley flat road. This way you will be able to make a better decision witch one will work for you. Thees units are adjustable like the factory ones.
Leonard
nollid
1974 pinto runabout
1971 pinto
1971 wrecked pinto
nollid
does any one know who sells a new vacuum advance?
thanks
1974 pinto runabout
1971 pinto
1971 wrecked pinto
