Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 02/05/2020 11:06 am
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 03/15/2023 02:16 pm
78-80 Windshield
Date: 10/29/2021 03:11 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 04/24/2018 11:45 am
1977 Cruiser
Date: 06/29/2019 06:28 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
  • Online today: 507
  • Guests: 564
  • Total: 564
Need a wiring diagram for a 71
Started by Reed, September 22, 2008, 04:12:41 PM
Reed
Thanks Fred!  For some reason I thought the backup switch and neutral start switch were the same on these cars.  I also havethe red with blue tracer wire going to the starter relay, so it is probably the same.  I will check the ignition switch output and see what's what.   :laugh:
Doug youre right they are seperate. Reed I have 74 up, start wire at selenoid is red with light blue tracer. My 74 drawing shows start wire at switch is still R/LTBLU . Switch is located top of colum inside lower colum area. Unplug and do ohm check or what ever youre using to out side selenoid wire. I dont know how to scan post or e-mail drawing, can copy and put in mail you know the old way with a stamp. If wire checks good then you need to buy 1 of my switches.  Fred   :D :)
I may be completely off base, but I thought the N.S. switch and the backup light switch were two seperate switches?
Reed
I thought my neutral start switch was bad since the motor won't turn over using th key, but last night I discovered that my reverse lights actually work.  So now I need to be able to trace the wires to see where the signal from the starter switch is getting lost on the way to the starter relay.
Anybody have a wiring diagram for a 71 Sedan that they would be willing to scan and post or e-mail to me?  Thanks.
