1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 04/27/2018 10:28 pm
Date: 08/03/2018 09:19 am
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
1971 Pinto
Date: 03/04/2017 11:28 pm
Date: 01/20/2018 07:51 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 07/04/2022 07:55 pm
Date: 08/08/2017 01:44 pm
  • Online today: 584
  • Guests: 559
  • Total: 559
Electric fuel pump install help
Started by Reed, September 19, 2008, 11:04:03 AM
Reed
Thanks Fred!  However, I might  not need it.  I followed apintonuts advice and blew some compressed air back through the fuel line to clear any clogs.  I heard a loud POP and then the air flowed freely.  The pump then worked but the carb flooded out.  So now I have to go back and reset the float level.  Anyway, it looks like I won't be installing an electric pump after all.   ::)
Black plastic switch with large red reset button, most are mounted lft or rt kick panel some in trunk, if I have a loose 1 I will get you picture.  Fred
Reed
OK.  Now I have to find out what a G switch is and what it looks like/where it is located.   :P
Reed go wire up to Ford `G' switch its a better way. Go to bone yard any injected Ford will have 1. Fred   :)
Reed
I think my fuel pump died, and nobody has one in stock.  So I am going to try an electric pump.  I want to wire it through an oil pressure switch, but I don't know which one to buy.  Can I splice into the factory sending unit for the idiot light?  If not, can someone give me a part number for another oil pressure switch that I can use without too much trouble?
Thanks.
