1980 hood needed
Date: 04/23/2020 10:41 pm
Date: 04/12/2017 06:57 pm
Date: 11/05/2020 06:32 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
1978 pinto grill
Date: 07/24/2018 02:18 pm
1980 PINTO for sale
Date: 06/19/2017 02:51 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Electrical
Date: 03/29/2017 11:37 am
  • Online today: 529
  • Guests: 374
  • Total: 374
Help Needed Installing Timing Belt Without The Timing Belt Cover
Started by licketysplit, September 09, 2008, 06:46:52 PM
apintonut
Quote from: licketysplit on September 10, 2008, 10:52:12 PM
Hi guys! Well i called Esslinger today and talked to Gary and got the info i was looking for! As for the crank timing marker without the timing belt cover on? Line the timing marker up with the center of the crank to the center of the aux shift for TDC. As for the cam gear? Easy! With the cam cover off, turn the cam to where the #1 cam lobs are both pointed upward and level them. Now your cam is on TDC no mather where the cam pullie marker is pointed! Mark the front of the head with a pouch in line with the marker and it's easy to find again even with the cam cover on!!!!!! Later, Howard
good info
i knew about the crank line up but its been years since i need to use it
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
licketysplit
apintonut
ii think it goose top dead center.  there is a dot on the valve cover i think
licketysplit
The motor is a 2.3L. There isn't any holes in the cam sprocket, the marker is an arrow shape on the outside edge of the sprocket. There isn't any holes in the cam sprocket belt guide washer as well. Howard
apintonut
2.0 or 2.3 if u look at the cam sprocket one of the holes go all the way though and has a arrow put the hole at the top with the pointer pointing down and the the dist rotor on #! plug and the crank has #'s one it the block has a little pointer on it on the left side top of the pulley line that up with the 0
licketysplit
Hi guys! I need to find out how to find the alinement point for the cam pullie without the cam belt cover on it?? Is It from the cam center line to the aux shaft center line?? Howard
