Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 07/04/2022 07:55 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
pro stock front end
Date: 06/28/2019 07:43 pm
Date: 04/14/2023 06:15 am
Date: 06/28/2019 09:14 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 07/17/2018 09:49 pm
New cam
Date: 01/23/2017 05:11 pm
  • Online today: 600
  • Guests: 267
  • Total: 267
Let the painting begin!!
Started by CHEAPRACER, September 03, 2008, 10:13:30 PM
Your Pinto's looking great!!!!!! I just went thru this repaint a few months back.  It's amazing what a little paint will do when it comes to improving the appearance of your Pinto.  Good luck!!!  Looking forward to seeing the finished product.   Larry :police:
CHEAPRACER
and more
CHEAPRACER
Overshot my completion date almost by a year. Now my goal is at least by next years Knotts show. Some updated pics for you.
CHEAPRACER
I thought I had pics of the whole repair process but I was wrong. I cut out the rust on the inner and outer panel, welded in new panels pieces, sprayed them with metal etching primer, a couple coats of rustoleum, then a heavy dose of rubberized undercoating on the inside wheel well and deep in the rear compartment.May not be the perfect way of doing it but I'll find the source of the water leak and I'm sure the problem will be solved.
I don't know about him, but I used fiberglop to repair those spots on my wagon.
That rust spot is scary! I have it bad on my passenger side quarter panel in the exact same spot, just larger. How are you going to repair it?
CHEAPRACER
Quote from: smallfryefarm on January 23, 2009, 11:03:59 AM
Hey i was wondering what size those tires are on the front of the car. I have 15 inch wheels but i havent bought tires yet wondering how tall i can go with out rubbing.
165-80r-15 on 3.5" wheels. I have yet to rub them even with the front lowered about 2 inches but  I'm sure it's possible.
CHEAPRACER
My junkyard hood wasn't too straight and someone closed it with the air filter stud loose or something. It looks like a lot of filler from the picture but it's pretty thin skim coats of Evercoats polyester putty. Stuff works good for flattening panels if you have the patience but they price it like it contains gold.
And I just scored a gallon of Victory Red (ya I know it's a Chebby color) urethane base off ebay for $74.99!!! That's a savings of about $325. I'm going to assume it must be old stock, I'd hate it to be the other...
CHEAPRACER
Some pics of the only rust spot found
Thanks for the rivet nut idea & where to get it. That should get me able to get a mirror on the passenger side door. +1 for the info.  :)
CHEAPRACER
   The vise grip idea won't work with me, my arms are too thick and I can only get to the front nut. I've done my home work and the proper name for these are rivet nuts. The tools are sold for about $30-$150 on the net and they do make special pneumatic high dollar ones for production guys. My budget told me to check the local Harbor freight and, not to my surprise, they had one in stock for $16.99 with the 100 piece nut set for another 10 bucks. I'm still thinking about the nut set as it's aluminum and there are much better splined steel nuts on the market, but then again, it's only a mirror not the door so they should be fine.
   I've also tried, for the first time, Epoxy primer. Having used only polyester, 2k urethane, and good old lacquer in the past, I've found this stuff to be very shiny (almost as good as cheap paint) so you can see any imperfection in the body work before block sanding or painting. I'm not sure if all epoxies are this way but I'm using DynaTone by Alsa corp and it seems to be good stuff. If it sands well then this will be my primer of choice.
   The camera is loaned out as of this typing but I'll post pics soon.
CHEAPRACER
I'm just getting ready to try the vise grip method with a very small pair and if that don't work then it's drilling time. I injured my back & have been out of commission for awhile so tomorrow will be my 1st day back on the Pinto job.
I just had to do this while removing my old chrome mirror from my driver's side. I ended up using a 6" vice grip. I had to reach through the uppermost center hole in the door to reach it though. I have long and skinny arms though, which helped.
Did you ever get the blind nuts out? Curious minds want to know.....
CHEAPRACER
OK, problem already. I have the sport mirrors which are not coming off due to the blind nuts spinning in the body. I guess I'll have to drill them out so time to buy another tool kit I'll only use once. Good thing I love tools. Anyone with any better ideas. There doesn't seem to be enough room for vise grips to hold them. Thanks.
Good luck on your project! I can relate to your comments about "finding less time" to do things, which is why my car also is an extended project. 20 years ago, when I was in my 20's, I had the good fortune of living alone in a garage apartment, where I did a frame off restoration on a 1957 Chevy 2 dr hdtp that I bought, running and solid from California - for $800!! Like you said, those were good times - I could work on the car nearly every day without any hesitation, and while money was lean, time was abundant.
With my family now, and a house/lawn to maintain, and no good working space, it's a bigger challenge. The Pinto will still get finished, but on a much longer calendar. Have fun with yours!
CHEAPRACER
  Well, here I go into the biggest step I've taken so far on building my car.
  A little background of my painting talents include about 6 years of ROP education and I've got my name on more then 20 paint jobs over the years but I haven't picked up a paint gun now in over 8 years so the water stuff, low voc, Cal emissions crap is like starting over.
   I started my bodywork this past weekend to the surprise of how little dented up the Pinto really was. The biggest part of the whole thing, filler wise, was the replacement hood that I purchased to replace the one I had cut out for the upper intake manifold. I've since rotated and shortened that so a new uncut hood was on my list & I also plan to reinstall the scoop. After all was filled and sanded, I brought out my new can of polyester primer that didn't make a sound when the can was shaken. I guess it wouldn't if it was hard as a rock now would it? Back to the paint store I went, who a day earlier said they would be open on Sat until noon, only to see a "closed for Labor day weekend" sign on the door. Well, I'll try everyone else...no luck closed. Called 3 Napa's and found one with primer, showed up to find out they lied to me about having quart sized and a gallon was over 100.00. I can buy the best for less then that before I'd pay for some no name brand so I bought a simple can of Duplicolor to cover my metal until my original store opened back up for business.
  I've found it's harder now to find time then ever for my project. It seems there is more lawn to mow or more kids to attend to. I'm predicting a 3-4 month long timeline when I could have done it in 3 weeks 20 years ago.
  One final thought though, I'm having fun, not getting burned out, and it's turning out pretty good so far so here's a few pics and thanks for looking
Edited 9-4; Alright, how come I spelled lawn as glbutt or was that a trick.
