78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 06/24/2020 06:12 am
Date: 05/13/2021 05:29 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Date: 07/08/2017 08:25 pm
Date: 07/17/2018 09:22 pm
1976 Pinto
Date: 10/24/2017 02:00 pm
Date: 10/24/2019 01:45 pm
Date: 10/26/2020 03:24 pm
  • Online today: 506
  • Guests: 291
  • Total: 291
V6 radiator in a 4 cylinder car
Started by volksnut, September 01, 2008, 06:44:06 PM
volksnut
well after looking at every avenue I called a radiator shop, Gordie you were right, I got the upper and lower outlets moved for $68. Not too bad   thanks guys
gordie
You can also have any radiator shop fill one outlet and put the correct size on the other side and eliminate all of the plumbing.
Ironman
I used a piece of exhaust pipe when I did the engine swap in my truck 11 years ago,.. still has the same pipe, and the same hose. I drive it everyday. Nice work on the VW.
Mick
Ironman
CHEAPRACER
Ahh what great memories, built a hot 1914 once, only had one kill and that was of a late 80's GTA Trans Am before some importer made an offer for the car that my friend couldn't refuse.
volksnut
thanks Jim, I like cheap...here's what I put together...it might not be a Pinto, but cool still
And spanking some imports
CHEAPRACER
Nope. Mine was even chrome plated, probably came from someones sink or something. Just remember to flare the ends just a bit so the hoses won't come off too easily.
volksnut
does it have to be copper pipe ?  thanks for the info
CHEAPRACER
You will probably have to use a short rubber hose elbow coming off the radiator and connect that to a staright metal pipe going in the direction of the other side of the engine and reconect it back to a second elbow pipe. I've done this before running a Pontiac Fiero aluminum radiator in my last Pinto and it works great.
volksnut
yes I know another question. But the daughter is on a limited budget. As you know her v6 took a crap, I installed a 2.3 and I'm finishing the swap but running into a few problems. The radiator was just rebuilt just before she blew the motor that's why i would like to keep it. The problem is the lower neck is on the drivers side and the water pump is on the pass side. Anyone know of a hose to use, I tried the flex hose route but none are long enough with 1 1/4" on one end and 1 1/2" on the other. Anyone here done this swap before...or I guess if someone needs a V6 Mustang II radiator w/ac, I'll swap for a 4 cylinder unit with a/c in the same shape.
