74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
Date: 08/01/2023 06:53 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 03/17/2019 03:57 am
Date: 12/31/2017 11:14 pm
Date: 05/18/2020 10:22 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
  • Online today: 531
  • Guests: 515
  • Total: 515
question on oil seperator/pcv valve
Started by volksnut, September 01, 2008, 04:48:11 PM
volksnut
it's a D port head...The circle track guys use them, the Racer Walsh adapter centers the 2 barrel 1 inch over the 4 ports, I then knife edged/ported the ports for a nice transition.  This is what they look like, straight from the Racer Walsh web site
adaptor efi 2bbl 1" Alum
RWA1232A adaptor efi 2bbl 1" Alum. This allows you to add a Holley 350/500 to your EFI intake.
manifold efi intake the works
manifold efi intake the works. This is a fully ported and polished intake. If your are seeking the most powerful intake to fit a production head on a 2.3L, then this is the intake for you.
Quote from: volksnut on September 01, 2008, 04:48:11 PM
I'll be running the lower efi intake with a 350 Holley 2 barrel on the daughters 2.3 motor. My question is where does everyone hook up the hose from the seperator/pcv to intake. Or is there another avenue. There's no provision on the Racer Walsh carb adapter...any ideas   thanks
I don't know how that manifold could be used with a 2 or 4bl carb. without a lot of work, and/or some sort of plenum. Unlike a regular 2 or 4bl manifold, on those each runner goes to an independent cylinder. The stock 2.3 one will let you bolt a 2bl right to it if you remove or modify the EGR plate.
volksnut
