Automatic transmission
Date: 02/13/2021 02:52 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 09/01/2017 07:52 am
Date: 09/03/2018 08:58 am
1978 hatch back
Date: 11/29/2019 03:18 pm
Date: 01/10/2022 03:41 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 12/04/2018 07:40 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 515
  • Guests: 444
  • Total: 444
Gas tank removal - how?
Started by popbumper, August 29, 2008, 04:16:35 PM
Well i would make sure that your battery is disconnected to be sure, Then all you have to do is Support it on something like a Jack(especially if it has fuel in it) and disconnect the lines then release the Straps, Slowly bringing it down. generally a simple procedure i would think hope this helps
All:
  My tank has a leak at the sending unit, you can see the fuel collecting at the sender and then "flowing" to the bottom surface of the tank. It is NOT excessive, as there is no active drip, but it definitely IS leaking.
What is the "standard procedure" for removing a gas tank SAFELY and what steps / hazards (besides the obvious) are involved?
I plan to get under the back and and completely restore the axle and everything, so this would be part of the effort. Thanks!
