1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Racing seats
Date: 10/24/2019 09:41 pm
Date: 01/24/2017 12:36 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
78 windshield trim
Date: 02/01/2020 08:46 am
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
2 Station Wagons for sale
Date: 04/20/2018 11:10 am
  • Online today: 533
  • Guests: 345
  • Total: 345
2.3 question
Started by demoiowa89r, August 27, 2008, 01:23:13 AM
Quote from: Fred Morgan on September 07, 2008, 01:46:02 PM
That rocker roller head is higher performance and you will have a lot of fun with intake because those are larger  `D'  port. I use the large 2 bore carb and fabricate my own intake man.. Fred    :)
None of the 3 "Ranger" heads that I pulled the roller cams out of were "D" ports. IIRC: Even the earlier "Ranger" head was a round port.
One more time:
Quote from: 77turbopinto on September 07, 2008, 08:18:38 AM
.....Neither the head or the factory roller cam for the 2.3 are "performance parts".....
Quote from: demoiowa89r on September 08, 2008, 12:45:31 AM
will the older intake fit on that head. how do you get a 2bbl rochester to fit on the intake? is there a certain adapter i would have to get?
The "roller head" is an 8 plug head and has its own intake bolt pattern so a stock Pinto intake will not 'direct-bolt' to it.
Quote from: earthquake on September 08, 2008, 01:53:47 AM
A rodchester? A 1 in spacer and the 350 cfm 2300 holly bolts rite on.
Earthquake is talking about the stock Pinto intake, not any EFI one.
Quote from: demoiowa89r on September 08, 2008, 01:56:17 AM
oooic. will 2300 holley fit on and efi intake? also are there any other things i would have to do to make the head fit on the block?
Not the EFI intake. The head will bolt right to the block; no problem. Unless you do lots of modifications, you will not be able to use any other intake or accessory brackets except those made for the 8 plug head.
Quote from: earthquake on September 08, 2008, 02:07:59 AM
That would be a ton of work.It bolts rite on the carb manifold though.The pattern for the EGR plate is the same as the carb base.You just need a one in spacer for a plenum top,Bout it.
    Doc.
Yes, swapping manifolds would be work. Again, as he mentioned about "bolts rite on", Earthquake is talking about the stock 2.3 Pinto intake, not any EFI one.
demoiowa89r
thanks for the help.. i'm building a new derby engine over the winter and i want a little bit better engine. the one i have now doesn't have the power i need and loses a ton when it gets hot... i hope this stuff helps it out..
Proud owner of a 74 pinto sedan. NON-DERBY
a 78 hatch. derby car.
a 73 wagon. derby car.
earthquake
    Doc.
demoiowa89r
earthquake
demoiowa89r
Quote from: demoiowa89r on September 06, 2008, 10:43:39 PM
hey guys got another question for ya. what are the advantages of putting a roller head from a pre 93 ranger on a 78 2.3? a guy has said to do this for better performance. i was just curious how much if any...thanks guys..
Was the SELLER of that item(S) telling you it was a "performance upgrade"?
Neither the head or the factory roller cam for the 2.3 are "performance parts", however the cam does reduce friction. This reduction in friction is not a driver noticeable thing, but it might be detected on a track or dyno.
The best 'gain' you get from the roller is significantly reduced likelyhood of the cam failing.
You don't need the head as the cam with fit the Pinto 2.3 head.
demoiowa89r
demoiowa89r
i do but basically  front suspension and i'm not sure how straight it is i know my spindles are still good, and the rack and pin, but they won't be available til next spring... i'm looking at buying a few more wagons so when i get them i'll let you know..
Since you're a Demo guy in Iowa, would you have any spare Pinto parts that you would sell?
None that I'm aware of, same engine put in different cars.
demoiowa89r
are there any performance differences between a 2.3 from a 75 pinto and a 2.3 from a 75 mustang 2?
