Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 09/19/2019 04:43 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 08/09/2018 07:49 am
Various Pinto stuff for sale.
Date: 11/21/2018 01:56 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
  • Online today: 533
  • Guests: 325
  • Total: 325
TURBO HEAD SWAP QUESTION
Started by DIRTTRAX, August 26, 2008, 10:39:49 AM
DIRTTRAX
Quote from: 77turbopinto on August 26, 2008, 03:19:10 PM
Unless you do ECU work, you have a limiter set to about 6250 RPM. The 2.3T have a fantasicly durable bottom end, and unless you have a known problem, you are most likely better off not touching it.
Are you thinking about removing the turbo and running a N/A engine in the car? Keep in mind the stock T/Cs have between 150 and 195HP depending on the ECU (vam, injectors) and are VERY easy to up the HP too. You needs lots to get a n/a 2.3 to those levels AND be durable and drivable.
well what im actually wanting to do is pull the motor/turbo and put it in one of my numerous pintos, i alread have one now thats got a good motor in it thats fast, and sounds as mean as a v-8 hitting, but i want a turbo pinto, cuz ive read some articles about some insane horsepower from the turbo cars.
Hey, I will hurry and put my motor together then........ ;D
if you're talking about a 2.3 i can't help you with anything.  in the past i ran a 2.0 with a turbo and i ran it with a high CR (flat tops/milled & ported head) and lots of boost.
throttle response was outstanding (obviously) the     turbo was a garrett t-04 with a .96 trim turbine housing.
CR was probably along the lines of 10:1.  I really didn't have any bottom end problems with the motor but i did regularily melt the pistons. i got REAL GOOD at swapping rod/piston assemblies.
the ring lands would go 1st then they would just melt.
but boy did it run good :hypno:
ps: brad;  i want to make it down your way some day  to visit.  i haven't had a ride in a fast car for decades.  i NEED it!
Quote from: CHEAPRACER on August 26, 2008, 10:19:16 PM
I say run the flat tops and massage a little metal out of the stock combustion chambers to lower the compression a bit.
Good point  :)
CHEAPRACER
DIRTTRAX
Quote from: 77turbopinto on August 26, 2008, 01:41:03 PM
Whats wrong with your T/C's bottom end?
its supposed to be good, dont know.  i got some motors i turned
9000+ regularly and i know they are dependable and light weight assemblies, and i may be better off to forget the turbo and just run one,  i was just wanting to make horsepower with what i had and figured one of my bottom ends would be better, if i could get the turbo figured out.  thanx
Quote from: 77turbopinto on August 26, 2008, 01:43:39 PM
Maybe turn off the caps lock?
What, I cant hear you................................. ;D
Quote from: DIRTTRAX on August 26, 2008, 10:39:49 AM
.....ANY ADVICE WOULD BE GREAT THANKS.
Quote from: DIRTTRAX on August 26, 2008, 12:42:32 PM
yeah they are forged for sure, i know its gonna have alot of compression, thats why i was aking if it would or could be made work.
You can run a turbo on a high compression motor but you will need to run low boost and back the timing off as the boost comes up.
DIRTTRAX
Quote from: DIRTTRAX on August 26, 2008, 11:48:04 AM
IM NOT SURE ABOUT THE BOOST, REALLY DONT KNOW WHAT U MEAN.  THE PISTONS WERE THE BEST WEISCO SOLD AT THE TIME, LIGHTEST AND STRONGEST. LIKE I SAID, I KNOW NOTHING ABOUT THE TURBOS, JUST TRYING TO LEARN
You might have forged pistons which would be good. You still might have a little to much compresion ratio for a bunch of boost.
DIRTTRAX
I AM A RETIRED MINISTOCK RACER, SO I HAVE SEVERAL GOOD BOTTOM ENDS, AND WOULD LIKE TO PUT ONE IN MY TURBO COUPE FOR THE STREETS, MY QUESTION IS, CAN I TAKE THE HEAD AND TURBO SETUP AND PUT IT ON ONE OF MY BOTTOM ENDS THAT HAS FLATTOPS?  IVE HEARD U NEED TO RUN LOW COMPRESSION WITH TURBOS, BUT IM NOT FAMIALIAR WITH THEM.  IF THE COMPRESSION IS TO MUCH, WHAT WILL IT DO OR HURT?
It would really depend on how much boost you put to it, and if the pistons are normal cast ones. If the C/R is too high you will burn up the motor. Also, you will need to ad a oil return line to the block. Yes, you could just put the return to the oil pan, but you would have to make sure there is NO restriction.
DIRTTRAX
