Date: 08/13/2018 02:46 pm
Date: 01/18/2017 05:35 pm
1980 Pinto taillights
Date: 12/26/2017 03:48 pm
Date: 11/29/2018 10:26 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Date: 03/29/2019 07:20 am
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
Pinto for sale
Date: 04/19/2017 10:15 am
  • Online today: 152
  • Guests: 126
  • Total: 126
insturment cluster pin lay out
Started by wedge446, August 25, 2008, 07:48:02 PM
wedge446
I haven`t cut the fuel gauge wires yet but I did try to wire in a fuel gauge(autometer)just to see if it was going to work...
All the thing did was go to max full and stayed there, even unhooked...
I may have fried it...Looks like I`m going to just get a fuel cell w/sender and be done with it. And a new gauge, I wonder if summit would swap it?
Quote from: wedge446 on August 25, 2008, 07:48:02 PM
I`m installing a new dash and gauges in my 75 wagon and thought I would pass along the plugs pin layout for anyone who wants it.
The plug is numbered if you look real close 1 through 14
1. goes thru a little square box then to the fuel gauge.. 2 wires, 1 black, 1 black w/green stripe
2. Ground        2 wires, both black
3. Bright light indicator light                                            1 wire, green w/black stripe
4. Lift gate open indicator light                                       1 wire, black
5. Seat belt indicator light                                               1 wire, green
6. Engine indicator light                                                  1 wire, red w/white stripe
7. Goes to the other side of the fuel gauge                    1 wire, yellow w/white stripe
8. Right turn indicator light                                              1 wire, green w/red stripe
9. Left turn indicator light                                                1 wire, black
10. Dash lights pos.                                                        2 wires, 1 green w/red dots, 1 purple w/white stripe
11. Dash lights neg.                                                        1 wire, red
12. Brake indicator light                                                  2 wires, 1 blue w/red stripe, 1 blue w/purple stripe
13. Alt. indicator light                                                      1 wire, green w/white stripe
14 Alt. indicator light                                                       1 wire, white w/blue stripe
I tried to wire in a autometer fuel gauge made for fords but I`m not sure if it works right.. Need to run it to get the level down.
I`m also unsure how to wire the alt. using the dash wires..I may just run a volt gauge and be done with it.
Hope this helps someone out there.
Great info. Keep in mind that there are at least 4 different pin-out arrangements depending on the year and options.
Similar thread here:
http://www.fordpinto.com/smf/index.php/topic,8023.0.html
wedge446
